christfr
well ya know when you have a match set you would rather die than junk one? well i love this tag set and part of the reason is im gonna say we were born the same year or close to it but they are just so pretty.. anyway the dryer is a dream never a problem but this washer has been a thorn im my side since day one.. when i got the machine a good 7 years ago the tub nut was broken and the agi was stuck.. so i broke the agi apart to get the tub out well in doing so i messed up something in the trans causing a no spin.. so i got a used trans put that in and all was fine.. then the cluch started sticking it either would spin or would not spin so i got a clutch..then it was fine again.. then it started to leak oil (just a little) so apart again it came too put a seal in.. all was fine again.. so in fall i used it and it started knocking and sort of sticking at the end of each stroke of the agi so i parked it.. then last month i look in the garage and there is a huge pool of oil under the machine so just for kicks i plug it in and the trans is half way locked.. so at this point im done.. i love the look of that machine but to be honest i dont like the small tub and sort of crappy turn over so i thought what can i do now cause at this point the machine is trash.. now i do have a big tub early 80s flat trans machine just sitting in the garage that i got for free from this really nice old gal in her early 90s (so you know it never got much use), well i decided to just switch the outer skins and have a pretty retro look with a newer bigger working machine.. so thats what i did.. i know its not really the correct way to fix the old machine but what the hell.
