bradross
Since the original thread has now dropped off into the archives, I wanted to share this new one with those interested.
The scrubbing and buffing of the tub interior continues. For the most recent sanding, I used 60 - yes, 60 - grit sandpaper, followed by finer 120 grit. Then a little scrubbing with an SOS pad and the following photo shows the results. Unfortunately, the areas I repaired with JB Weld "Steel Stik" will not buff to a shine. But better that than a leaking tub!
The "before" photo was taken when I just brought it back from Iowa at the end of August. I've been using the machine fairly regularly, and I must say - it is fun! Would only be better if I had room for rinse tubs, and had a floor drain!
By the way, if anybody is attempting to repair the top roll (made of softer rubber) of any gashes, try using "Permatex" black gasket maker. I used it where the two rollers were "welded" together from the hot Iowa sun, and it was left with a permanent flat area the width of the roll. I spread it on with a finger, and then took a piece a waxed paper and pulled it firmly across the length of the roll, conforming it to the curve. It turned out beautifully, and now works smoothly when the pressure of the rolls is on. I'll try to post a pic of it later.
