James -
The first picture is machines which were featured in the 1975 Christmas catalog. I remember this ad clearly as an 11-year old being absolutely fascinated by that comparison of the two washers. Which one to pick?!!! At the time we had a Penta-Vane 'powered' large cap machine already, so the other, with the Roto-Swirl, which I was missing from the recently departed 1961, was my choice.
You don't see the model tag from the front left foot because this didn't happen in manufacturing until late 1975 or early 1976. I had one early black-panel '76 machine (a white version of my green beast) which had the old lid tag and the rear cabinet larger tag instead of the front tag. These were probably photographed in summer 1975 in preparation for that catalog, thus before the change was made.
Both these models are 200-series machines. The machine on the left, is model 110.72520100. It's a HUGE step-up from the single speed, all painted (non-porcelain top) 100-series. This machine has an unusual "cold wash option" as it's temp selection knob, and two water levels, which is par for a 200 series. Odd though that it has chromed knobs, a self cleaning filter, two speeds, and the porcelain top and lid.
The machine on the right is 110.72625100, which is a 1976 200 series. Any model number with a 5 or higher in the 5th position right of the decimal denotes standard capacity. Note the walnut/black insert in the escutcheon is not present on the '76 but is on the '75. This is another bizarre model in some ways because even the 1976 60-series washer (the Green Beast again) does not have the features that this model does. The GB has one less water level (which makes no difference to me in a standard cap as mine are always full or I don't run them), a manual filter, and the straight vane agi.
Both these machines are part of the VERY select few plastic control panel models, of which there were many, which were available in colors other than white. These are also a bit unique in that Sears seldom intentionally matched a large capacity dryer with a standard washer (makes for wonderful low or non-wrinkled loads). Much more common was a large cap washer with a standard dryer.
I still like looking at that ad!
Gordon
