V-Zug Adora arrive in UK...!!!
V-Zug Adora SLQ Washer & Heat Pump Dryer
They look quite solid machines Mike, almost retro-ee in a way, refreshing to see square corners etc.....
All I need to do now is peel off the protective visor cover and switch on selecting the installation programme, which creates an very unbalanced load (the baffles use water fill for balancing - so it pumps 1 full, 1 half & one empty)the machine then goes into a fast spin and if its levelled correctly then it stops, OR flashes "CHECK STABILITY"
