Various Finds 7/14/24
qsd-dan
Jan 24, 2007
7,235
West
Maytag 641C d=Dryer
https://www.facebook.com/marketplac...wse_serp:4cfd53b9-3211-4704-9678-cd8fee5c561a
Frigidaire 1-18 Dryer
https://www.facebook.com/marketplac...wse_serp:580f6d95-3f76-4c16-9a6e-cd2ab5b68ca5
Early 80's Knemore Washer/Dryer
Free 90's Maytag Washer
Maytag Coin-op Set
1968-1971 A606 with DG308
Late 1971-1974 KA606
https://www.facebook.com/marketplac...wse_serp:f3ffe811-c146-481b-9ec9-0312d4a2eb94
Early Frigidaire Dryer
KUDS220T
https://www.facebook.com/marketplac...wse_serp:f50d6251-879f-4c2e-be58-fb8440eda034
Yellow Frigidaire Range
https://www.facebook.com/marketplac...wse_serp:170832fe-22cf-4e1b-80dc-3ee8dfb60e3d
GE Dryer
https://www.facebook.com/marketplac...wse_serp:dc27c02c-0487-4f31-8d11-ee93ea25ada7
DE608 Dryer for cheap
https://www.facebook.com/marketplac...wse_serp:d775563d-76d8-4d67-a89c-8eb866d07d1f
GE Dryer
https://www.facebook.com/marketplac...wse_serp:6e1ed90a-204d-4286-9cb3-d2889d55fdba
612/DG713
https://www.facebook.com/marketplac...wse_serp:75edb566-9807-4f72-a68c-f818b8adc72e
Cornado
https://www.facebook.com/marketplac...wse_serp:bf4d0da1-08b1-4704-af8e-8d344cc165c4
Early Kenmore Dryer
https://www.facebook.com/marketplac...wse_serp:90216f96-092b-4246-9d20-c4ef56b727e0
That early 80’s Kenmore set seems to be in great shape, though the center post seals will have to be checked since it has the short center post as opposed to the tall center post from 1977 and up.
That mid 50’s Kenmore dryer appears to be in good shape from the console, but no photo of the drum, unfortunately.
Free Maytag washer and yellow Frigidaire range are gone. Wasn't expecting things to disappear that quick. Appears to be more traffic through this forum than I realized.
Lots of vintage Appliance fines
That 50s Kenmore electric dryer is one of the high-speed 50 amp models.
Hi Sean, the post 77 Belt Dr. machines with the shorter center post. Never have center post seal problems just like the direct drive machines. You almost never see water leaking into the main bearings, adding the second seal, the machine was several times more durable than the early machines with just one seal. Those were the problem machines, the model like you have with just one upper center post seal generally only lasted 8 to 12 years in normal family use before the bearings were shot once they put the second seal in you almost never saw problem no matter how long the machine lasted.
John
Huh, mine was in service for 42 years (in service from 1963 to 2005), no bearing noises when I first got it. However, started making noise after I put it back together in the spring of ‘21. Packed the center post with some grease to get more life out of the bearings, didn’t change from 2021 to early 2023 when the timer broke.
Btw, any updates with the parts timer?
The Kenmore washer is a 1983 model built the 46th week of 1986 making it one of the very last belt drives made. The dryer is a 1981 model built the 46th week of 1982. Interesting how the two machines ended up side by side being built the same week 4 years apart.
1955 Kenmore High Speed dryer
As John mentioned, the Kenmore dryer is a 50A dryer, and in fact is Kenmore's first 50A High Speed Dryer, for the 1955 model year, model number 110.553890.
While the exhaust was updated to a 4" outlet, the dryer still does not have the top mount lint filter.
Photos saved for the archives, as well as a screen shot of the service manual mention of this model and the wiring diagram.
Ben
