Vintage Clock Find
I picked the clock up, and studied it. It clearly had wear & tear--the finish looks better in the photo above than in person. But the worst problem came to light when I turned it around. No back. And the movement had been replaced by a modern quartz movement. Isn't that sort of like putting Whirlpool DD internals into a 60s Kenmore BD?
Making matters worse, when I looked carefully at the moment, I saw: "Made in China." Oh, how the mighty clock has fallen!
Although, I guess it could have been worse. The person making the conversion could have cut out a rectangle on the dial, and installed a digital clock.
While I'd prefer this clock authentic, the conversion does make it practical for me. Power failure season is coming, and I've been thinking of getting a quartz clock for my living room. This clock is something I actually like, unlike most thrift store quartz clocks I see which appear to be designed with the "how cheap, ugly, or tacky can we make this piece of junk?" goal.
While I applaud the previous owners ingenuity, I must scold them for ruining a beautiful vintage electric clock. It's very hard to find a working electric clock where the case is in good shape. But as long as you're happy with it, that's all that matters.
Clock Freak Here
I am a clock freak but typically gravitate towards clocks that chime or coo-coo.
Malcolm
I like clocks too. I have been known to find a nice mantle clock with great chimes, put in a new movement and give them as gifts to friends.
I particularly like the mantel clocks which sound more like grandfather clocks than jewlery boxes.
I like it too
I'm not so bothered by the modern movement. To me, it's been saved, and it's been allowed to continue on, still being a useable clock.
Yes, I have to agree that it's really too bad the original movement is gone. I tend to be a purist, and I don't like conversions like this. I can see doing a conversion if the original movement is broken beyond repair. Although, if this clock had come my way with a broken movement, I'd probably have left it alone, and considered it a decorative object.
Past that, in this case, I really wish the person doing the conversion had put the back on again. While it's strictly not necessary, and it's easier changing a battery with an open back, the outward appearance would be considerably better looking--and more authentic looking--if that back were still in place. Plus, the back helped hold the dial assembly in place. (The dial assembly, which also holds the movement, has 2 threaded poles that run through the case. The back obviously attached to those poles, and would help "clamp" the front to the case.)
At least, the really important stuff--the case and the dial--survived. And, while I don't like the conversion, I might as well use this as a clock, since I can use a quartz clock.
Although, I have been thinking that it would be an interesting project to try converting it back to electric. I think electric movements are probably NLA, but I might stumble across one. Possibly inside a case that is beyond any hope of repair.
I like spring powered or gravity powered weight driven clocks-just wind and set them-no batteries or cords required.There are so many quartz battery clocks around they are getting boring.
