Learning more but still confused
Now I know that auto-dry and timed-dry are separate on the 1972 Kenmore, and that helps.
I think part of the reason I'm still confused is because the auto-dry setting on our modern Kenmore doesn't seem to act any differently than the timed-dry. The only difference I can see is that the cool-down cycle seems to run longer on auto-dry than on timed-dry. Maybe the auto-dry doesn't work correctly on our dryer?
I attached a photo of the control panel. It doesn't have settings like "hard dry," "medium dry" or "soft dry." Maybe those selections are only on the older Kenmores, like the 1972 model?
If I'm understanding the description of how auto-dry works, then I should be able to put a load of wet jeans or towels in the dryer, set it at low heat, set the timer dial for delicates/permanent press, and the timer will shut off and on as needed, allowing the heating element to cycle off and on, until the items are dry? It would run for as long as it needed to get the items dry?
If we set the temperature at high heat, it would operate the same way, except it would take less time overall, because when the heating element came on, it would be at a higher temperature, correct?
That isn't how it would work with our dryer, though. In the above scenario with low-heat, the dryer would run for about 10 minutes at low-heat, then another 5 minutes with air-only, then shut off. The items wouldn't be dry. At the high-heat setting, they would be dryer, but still not completely dry.
I do appreciate the education I'm getting here!
