Vintage KitchenAid mixer 4C
jasonlittle
Sep 20, 2017
166
Southern iowa
I just bought this and I am super excited to finally have it. I unboxed it tonight and it runs good but I’m sure it needs serviced so tomorrow I’m going to take it apart and Clean and re-grease it. But I have been trying to figure out how old it is but haven’t had much luck looking online. Was hoping maybe someone here might have an idea about its age?
Check out this article
<span style="font-family: 'comic sans ms', sans-serif;">I found a link where you can ask KitchenAid for the exact age of your machine.  I'm not sure how well it works but it's worth a shot.</span>
<span style="font-family: 'comic sans ms', sans-serif;">https://www.hunker.com/12002866/how-to-find-out-how-old-my-kitchenaid-mixer-is</span>
<span style="font-family: 'comic sans ms', sans-serif;">I have one in white and for some reason I'm thinking that's an early to mid 50's model.  Others may have a better date for you.</span>
<span style="font-family: 'comic sans ms', sans-serif;">Good luck.</span>
I have one just like it. Still going strong. I was going to say mid-60's.
Two issues about these, they don't have a very low, low-speed--------so beware when adding liquids or eggs to a flour mixture or it will slosh it right over the top. They will also throw the flour over the side. These really do need the splash-guard.
Steve is right
This applies to all kitchen aids, any recipe like gingerbread that requires the addition of say boiling water at the end of the recipe,,,dont make it in a kitchen aid it will sling it out everywhere.
Nice mixer! Where did you find it?
I have the white pouring shields for both my 45 and 4C machines to prevent the splattering of ingredients. Absent the pouring shields, could you not fold the boiling water in by hand or just add it bit by bit? A quarter cup at a time on low seems like it would not create a disaster. I found that I could not add the boiling syrup to the beaten egg whites for divinity with the KA because it would be slung to the bowl by the whip, but had to shut the machine off and add a small glob then restart it and it made great candy.
Thanks I was thinking 60s but wasn’t sure. I found it on eBay. I made a chocolate cake with it today. There is a few on there still. But one is all green without the polished aluminum top and the other has the pin replaced with a bolt and the other one had the stainless bowl and I wanted the glass. So this was the only one that fit all my criteria.lol but it needs serviced. I took it apart and greased the gear box but the motor doesn’t run right. It’s very clanky in lower speeds. I just don’t have the experience to mess with that part. I have watched videos on it but still couldn’t figure out what’s wrong with it although I’m sure it has something to do with the speed control. When I wiggle it with a screw driver it takes the clanky out of it. It also smells a little hot after running it on low even with nothing in it. I suppose I’m probably gonna have to send it off and have it fixed by someone with more experience. There is a guy in Michigan who really seems to be very knowledgeable about them. That’s all he does for a living. I sent him a message this evening.
He’s on YouTube. It’s called vintage mixers and more. He has tons of videos on there with step-by-step instructions on how to completely tear them down and redo them. I was able to figure out what was wrong with mine without having to send it in. I had already completely tore it down cleaned the gearbox and packed new grease in but the motor was still rattling even after I adjusted the speed and clean the speed plate of all the flower build up. There were some loose screws causing some of the motor housing to flex and rub on the Armature when the mixer was under a load. After tightening those screws it sounds and runs like a brand new mixer no more awful noises. This guy also has a Facebook page but I don’t have Facebook so I wasn’t able to check it out very well. I found it just by googling his business name of vintage mixers and more. His phone number is there he says to text or call. I text him and he actually responded quite swiftly. Seems like a very nice guy and judging on the videos on YouTube very knowledgeable on vintage mixers.
Only speed five
I am by no means an expert on this because this is the only mixer I have worked on so far. But judging on what I have learned from working on my own it sounds like the contacts on your mixer are stuck there for only allowing one speed.
Awesome find and . . .
This mixer can be fixed! Find Rick Margle's video of his disassembly of a KitchenAid 4C. The governor or speed control contacts may be stuck and that is easy to remedy. Just handle the parts carefully tag or label what you disconnect
While this mixer cannot knead dough, it sure can handle cookie dough and batter breads like Sally Lunn and brioche
This mixer is welcome in my Kitchen--I ideal model would be a 4-C in brushed chrome with a stainless bowl and a glass bowl backup and an extra beater (referred to as a combo flat beater & wire whip and splash guard--the white plastic one piece version.
