Vintage Retro Oven/Surface top and Vent fan top (harrison twp) MI
The Word Is: B-A-S-T-A-R-D
You know what this is?
This is a vintage Westy cooktop that originally had Corox units.
However, during the brief - and totally misguided - vogue for jen-you-wine Yurrpeen cast-iron hob units, replacement burner elements were available in the hob format. You could "update" your range to look like a newer one.
This cooktop could - and hopefully will - get a "redate" to roll back the "update."
Corox units.. still there under.. cast iron crap
Easily removed? Nearly like the waffle irons with the griddles on the obverse side...only not as conveeeeeeeeeeeeeenient.
Some of these just clipped onto the existing surface units. Even the replacement ones Sandy mentioned plugged into the existing receptacle, but with those you had to be more careful about matching up to your range's receptacle. Slobs thought they were eliminating cleaning drip bowls with these horrible units, but they were messy in their own way
Covered Elements
You can see that these were just the covers, they never made complete plug-in elements that would plug-in to a WH CT this old, so they could be easily be removed, however the CT looks pretty tired and WH CTs like these had crappy infinite switches so it would need a lot of work if you actually wanted to use this CT.
no coils
my sister just bought a new black and chrome stove (forgot the brand name) but it has no coils because she says, " no more cleaning those coils". I wouldn't mind a glass cooktop, say..maybe in an island, but prefer a real stove, gas or electric.
I can't imagine using this with those covers, but since John L. mentioned it, I'd remove those cast iron caps and go from there. This unit looks like it belongs in a cabin or smallish bungalow. What to pair with it? It's pretty spartan looking(if you love that look).
