I posted awhile back about wanting a gas range: https://www.automaticwasher.org/cgi-bin/TD/TD-VIEWTHREAD.cgi?89301
I'm going to see this beautiful Tappan early next week. Seller said it's from 1962 but I saw the same range in another ad that said it was from 1960. Seller said it was in a second kitchen and rarely used which looks to be the case - it looks pretty clean, especially the chrome! The first pic shows a knob missing, but it was found.
Does anyone know someone in St. Louis who could take a look at this and maybe clean and grease the burner valves too? I read you should do that with old ranges. I have someone to pick it up and install it, but haven't had luck finding someone who can give it a good look and tweak anything that needs it. It's not hooked up at the seller's place so I can't test it there.
I would definitely get a new flexible gas line for it. Are the metal ones or the yellow coated ones better?
Also, is there anything I should be looking at closely when I see it? I'll take a picture of the tag so I can figure out what year it's from, and lift the burner covers to take pictures of the guts. Anything else important?
Thanks!
Thanks!
