Late 60S Westinghouse TL Washer
Neat and now very rare washer, it will be neat to see if it works or can be fixed easily.
Some of these early WH TL washers even did a neutral drain if it has the " pre-pump " solenoid next to the motor, the solenoid would engage and loosen the drive belt so it would barely spin as the water would pump out.
I think some early WH TL machines also had a clutch on the motor so they were not so hard on belts, but later both these parts were eliminated and they just let the belt take the strain as the machine pumped out and got up to speed.
John L.
