Warm vs Cold Spray Rinse?
Chetlaham
Mar 11, 2013
5,543
United States
I've been thinking. Since water is forced through clothes during a spray rinse, does warm water make any difference over cold water? I know warm water relaxes fibers in a deep rinse for better rinsing out of detergents but does this also extend to a spray rinse?
My daily-driver machines run a cold rinse ... except the F&Ps should rinse at the same temp as wash on the Woolens cycle, and the Neppy TL has a Warm/Warm choice although I expect the ATC rinse warm is more limited than the ATC wash warm. I can get any temp for rinse on the three machines connected to the tub faucet in the master bathroom. Maybe I'll run an additional rinse at a warmer temp on a future load in there to observe any evidence of more detergent/suds removal than what occurs on the cold rinse (which is appreciably none).
cold water is better for knocking down suds and discouraging suds formation than warm water.
That may be, however using a low-sudsing detergent makes that a moot point.
I've been using the Windfresh powdered detergent for decades now and never had a problem.
Even in my Kenmore DD, it eliminates the suds-lock issue.
Having a washer that isn't prone to suds locking is key. In my situation of a water softener coupled with a tempering valve increasing both cold and warm temps (85F cold and 120F warm) plus increasing water volume and using non HE detergent dosed on the heavy side, the Maytag 806 should definitely be suds locking. It never does.
My Maytag A482 doesn't suds lock either, even with loads of foam after a wash.
That's if I use a higher sudsing detergent on occasion.
But the portable DD Kenmore struggles sometimes, because that warp-speed agitator foams up things.
