Wash pump running while draining
My 2015 Kenmore Elite (aka Kitchenaid product) with the Microclean filter starts draining with 4 short bursts of the drain pump and then the drain pump stays on while the wash circulation pump continues for another 15-20 seconds before the drain pump runs all by itself.
Fill During Wash
Whirlpool machines seem to start half way through the fill. Never understood why but its interesting to hear the pump gather strength.
@appnut- My Maytag is the same. The pump does 2-3 short bursts then stays on. I know why but don't know physics behind it. When you start the drain pump on a full tub of water the amount the comes out of the drain hose is small, but if you pulse the pump its seems to trigger almost a siphon or something because its start to drain like you would expect- fast.
My dishwasher has a reversing pump motor with separate impellers on the one shaft for wash and drain.  The spray arm sits directly atop the upper recirculation impeller.  The lower drain impeller is in a small sump.
Current draw on the motor is used to sense the proper fill level so it must run the pump during fill.
It runs the pump on an approx 15- to 20-second cycle (I haven't timed it exactly) for an approx 3-min drain period (I haven't timed it exactly) with momentary little pulses during the dwells.
Just noticing my current Miele dishwasher, which is from 2017 seems to start the drain pump along side the wash pump.
Perhaps it’s to ensure the filter clears?
European machines use a largely self cleaning filter approach, so the wash pump is sucking water through the sides of the filter, through the fine screens & the drain pump sucks from the bottom with just enough filtration to prevent its impeller being blocked, so most debris will be flushed down the drain.
I was just wondering if perhaps it’s designed to create a bit of turbulence in the filter as the drain pump operates, thus helping to clear the filter mesh mesh screens into the drain pump.
They clear pretty effectively on any machine I’ve had.
