washing machine water overflow
newgardener_tx
Nov 12, 2009
2
I have a five year old Maytag top load washing machine. When it goes to the rinse cycle the water doesn't stop and the machine does not run again and then the water overflows. I can hear clicks. Sounds like the indicator can't pass the Rinse. If I manually turn the indicator to pass the rinse when the water is at the right level the machine works. This happened once before and I had to change the woodfloor of the whole living room:(. I didn't do anything and it fixed by itself. But this time it is refusing to fix itself. Luckily I caught it before the water goes out of kichten. Is this a fixable problem? Is it possible DIY? Your help is greatly appreciated.
Thanks.
new gardener in Tx
Yup it's fixable.
Sounds like a timer issue. There are more people here who can give you a better idea, but I would look into a new timer.
What is your washer's model number? Some Maytags from that era are very very good, but others have a frightful reputation for colossal leaks. If it's a bad one, it would likely be good to get rid of it before the main seal fails. If it's a good one, fix it and keep it for ever.
I hope you have a good one,
Dave
Thanks. My machine is a Maytag Ensignia, oversize capacity plus. The model number is MAV645/AWW. Where can I get a new timer? Can I replace it by myself?
Ok.
I don't know where your washer falls in the good or bad category. Be glad it's not an SAV series (they were aweful).
A timer replacement can be a do-it-yourself job. First, go to a place like www.repairclinic.com, enter your model number, and find the timer. It will give you a part number for the timer and if it has been updated and there is a different timer available, it will tell you. This will also give you a price. You can use the part number to look on ebay or you can call your local appliance parts stores and get some prices from them.
Good luck,
Dave
About 2 months ago a coworker of mine approached me and asked "You work on washing machines, don't you?" I told her that I can depending on the problem. She explained that her washer (a 2 year old, Maytag badged Whirlpool, don't remember the model#) either would not fill OR would overflow (randomly, fortunately the washer is located in the garage).
After checking with a washer friend, we came to the conclusion it was the water level switch. I bought a new one and installed it. So for $30 (my good guy price) it's repaired and working just fine.
