washing pillows
historyman
Aug 24, 2006
109
Pittsburgh, PA/Aiken, SC
Recently tried to wash 2 twin size pillows in my FilterFlo, only to confirm what I was thinking to be true, i.e. the FilterFlo simply was not up the task at all. The spinning went very much out of balance and I ended up just throwing the pillows away. I knew they'd get lumpy but I tried to balance things out with both the pillows.
So..... Anyone have any luck/advice in washing pillows? Was it because my FL is only the standard size? I've washed pillows in my parents "super capacity" Amana with no problems. Any help would be appreciated.
Laundromat
I have an extra large capacity heavy duty Lady Kenmore. No problem with the balancing, but the pillows do not circulate and there is always these huge air pockets.<p> I take my pillows to the laundromat and use the large front loader there. Only Once have I had a pillow get twisted around in the case. <p> And oh how I would love to put a touch of bleach in the wash. but the pillows say "NO BLEACH" <p> who am I to argue with a pillow ?
Pillows don't generally do well in an agitator toploader. I have washed pillows (pairs) in my F&P, on Delicate (GWL08) or Handwash (IWL12), with lots of soaking time and minimal agitation with manual redistribution.
I have done pillows (singly and pairs) pretty well in my Calypso, and am looking forward to trying it in my Neppy TL when opportunity arises.
pillows
I like to wash my pillows in the He4t Kenmore. I can fit two pillows easily and they seem to do well. I like to wash them on sanatize. Throw them in the dryer and shake them out and shape them if necessary. Def. only do it in FL's though. Top loader would tear them up.
Jon
Probably not well, unless you redistribute the load (turn the pillows over etc) every few minutes. This isn't as easy as it sounds with large waterlogged pillows. They're heavy!
I'm with Tom. We take our pillows down to the washateria and use one of those Wascomat Triple loaders for our three standard sized pillows. Works perfectly.
We did this for the first time last fall. Our pillows were a few years old and we usually just toss them and buy new ones, but these were rather expensive ones.
They turned out even fluffier than new! The results were better than expected.
How often are you supposed to wash a down pillow?
Tom, Whirlcool and I Agree!
Best thing to do is put pillows in a large capacity front loader (two at a time).
Something else I learned...throw in a pair of old sneakers or a few tennis balls and wash them with the pillows, then move everything to the dryer when finished. The sneakers or tennis balls will help them dry faster and "pound" them back into shape.
I can wash two pillows at a time in my Frigidaire 2140 FL. I generally use a Soak cycle first to get out all the air pockets, then I run a regular wash (usually warm, heavy duty, extra spin, etc.). They come out great.
Front loaders work.
I've washed two pillows at a time in my LG front loader with great success. I didn't use the sanitize cycle because I thought it would ruin the feathers and down and just be too long in the wash. I used the delicate cycle with a little bleach during the first rinse. The only problem I've had on occasion is that the LG won't do the final spin because the pillows won't balance. After going in and manual redistributing them, it worked fine. Then I air dried them for one day and then fluffed them in the dryer. Worked great!
great advice so far...
should one avoid enzyme detergents when doing feathers?
i usually do my pillows (polyfilled in commercial FL) along with the whites or towels. the weight of the additional items in the drum helps beat the air out of them, imo.
I've used an OPL Wascomat triple-load for mine and they came out great. The on-premise model has a "rapid advance" feature - holding the start button in advances the timer as long as you hold it so you can easily modify the cycle as you like. I started with a pre-wash, advanced to spin to remove all the air from the ticking and then restarted on the regular cycle in hot water. The Wasco only has a 90g spin rating (about 550 rpm) so drying takes much loner. I brought the pillows home and gave them a proper spin and dried two at a time with old sneakers inside old pillow cases to knock the down clumps apart during drying.
Yes Bill, the tennis ball trick works great. We use that on our down comforter, but have never tried it with our pillows. We just stop the dryer every 5 minutes or so and refluff and dry some more. The tennis balls would make it much easier!
never with enzymes
I wash my down pillows in the front loader, one at a time. I throw in a few of those silly washer balls - you know the nonsense - their "magnetic" influence or whatever reduces detergent, etc. Horse feathers, but they do beat the air bubbles out of the pillow perfectly.
I use a special detergent for down jackets, vests, sleeping bags, etc. Enzymes and chlorine bleach destroy the feathers.
The same stupid balls beat the heck out of the pillow in the dryer - at very low heat - for seemingly hours until it is truly dry and fluffy again.
Clean sneakers would do the same, as noted above, I just happen to the have the balls.
I can't imagine a TL washing them successfully, but if I simply had to use one, I would let them soak for a long time first, to get the air out - and then use two to make sure it was in balance. Still think it would kill anything but a Maytag or "real" Speed Queen.
Best method of laundering down filled pillows, is the one follwed by housewives on both sides of the pond for ages; removing the filling from the casing, launder each on their own, then put the filling back into the casing.
Rationale behind this was simple: down and feathers are made of protien and as they break down from use, make dust. It is this dust many people are allergic to, not the down by the way. Also since pillows cradle our heads as we sleep, they are subject to all and sundry sort of substances. From skin and hair oils, to cosmetics, to saliva, to blood, to god only knows what else. While a good ticking keeps much of this muck on the outside, depending upon how often pillow slips are laundered, stuff builds up and eventually gets inside.
The movement of our heads and fluffing up of the pillow also contribute to breaking down of the filling by mechanical wear.
Laundering a pillow by immersing the entire article in water, or washing machine does not allow the muck,dust, dust mites, and every thing else to come out of the pillow. Indeed since down by nature is water repellent, often it takes much effort to even get the filling wet. Another problem is rinsing, for even if one gets the detergent and water solution inside the pillow, rinsing clean is a bit of a problem
Down and feather filled pillows have been around for ages, to launder them the old fashioned way is simple:
First cut open or open a seam on one end of the pillow enough to take out the filling. Next place the pillow inside a large mesh bag or clean pillow case at least twice as large as the pillow. Carefully baste the pillow case to the pillow (you want to prevent an I Love Lucy moment where down goes flying all over, however if one can move the filling out of the pillow and still keep the pillow case from moving basting is not required), and turning the pillow upside down, shake/move the filling into the pillow case/mesh bag.
With the pillow ticking empty, one can wash it to death in hot water using a good enzyme detergent if required. Take the pillow slip/mesh bag full of down and either wash it in a large wash tub or bath tub using either a down wash product, or even a clean rinsing shampoo in warm water, rinse well and spin dry. You can then put the pillow case filled with down into the dryer and dry on low until it is dry. Because the down is in a large bag/case, much larger than the pillow, down as room to move and fluff up. As with down duvets, adding tennis balls, or those down fluffing things into the dryer will help deal with clumps. Either way, take the thing out and beat it/fluff every now and then, returning it to the dryer until dry.
When both the casing and down are dry, reverse the above to put the down back into the casing. Sew casing closed and viola! You have a totally clean and dust free down filled pillow. Before closing the pillow, one can add more down/feathers to make it more puffy.
Commercial dry cleaners,laundries that offer "pillow cleaning" service use pretty much the same method, however it is done by a machine and instead of water air and ozone are used. Bascially down is sucked out of a pillow case (or dumped), where it goes into a chamber that is like a dryer on air fluff. There the down is exposed to air and ozone to clean and fluff up the down. Once the cycle is completed the down is air blown into the empty pillow ticking.
L.
I have had Fabulo0us results
I washed pillows in my Mom's top loading Maytag, and well, top loaders just do not do well with them, however, my Miele, which is only 6k did a fabulous job. I like to wash pillows on the soak cycle and on the delicate setting so it has pleanty of water to wash in.I would also try some oxy clean with it. Just a thought.
I don`t have a sewing machine nor a mesh bag.
So I always washed my down filled pillows, one at a time in a "small" Euro FL with good results.
No enzymes because feathers are protein and no fabric softener! Any detergent suitable for silk and wool may be good enough. Hot or even boiling hot water kills dustmites and the feathers cope well with high washing temperatures.
Rinsing and drying can be difficult, so I think it`s best to use a cotton cycle with good extraction.
Now I have syntethic fibre fillings, because their care is so much easier.
