Water Filters: Clear2-0 CWS100A Carafe
frigilux
Mar 3, 2007
12,665
The Minnesota Prairie
I've had a Brita water carafe water filter for about five years, but have never been too happy with it, nor have I been impressed with its limited filtering ability. In the meantime, I've become quite fond of buying cases of Nestle bottled water for $3.89 at Sam's Club.
In an effort to stop producing so much plastic trash, I decided to get a better filtering system. I figured I'd have to get an under-sink reverse osmosis system or something.
Consumer Reports just happened to rate water filters in their May issue and the Clear 2-0 CWS100A carafe scored very high. The highest scoring unit was an $1,800 reverse osmosis system (score of 99). Next highest was a Tersano Lotus LWT100 carafe with a score of 95 and a price of $150.
The Clear 2-0 carafe was third, with a score of 93 and a price of $30. So I ordered one from Amazon.com. It arrived today and I'm amazed at the quality of the water it produces.
All you do is put their aerator/adapter on your kitchen faucet and connect the pitcher to it via the quick-connect hose, which stores in the handle of the carafe. (It won't work with pull-out sprayer faucets.)
You get a pitcherful of water in about 35-40 seconds. The water tastes (and looks) really....pure. Clean. Untainted.
Highly recommended, and you can't beat the price. It outperformed all the other countertop, undersink, faucet-mounted, and reverse-osmosis systems they tested.
Here's a photo of the just-over-half-full carafe:
I have mixed feelings about the carafe style water filtrations system.
This is because many people stick the carafe full of filtered water in the fridge, and because it's not air-tight the water tends to acquire an off taste after a few hours. This is worse than plain tap water, IMHO.
I don't experience this problem with a sealed in-line filter for the refrigerator in-door water dispenser, unless it hasn't been used for a week or two. Better protection from off-odors in the fridge, I think.
Of course it's best to keep the fridge compartment squeaky clean so there are no odors in the first place, but...
Carafes are also not for people who require large quantities of filtered water. I use filtered water for drinking, making coffee or tea, and in bread dough, but I use tap water when boiling 5-6 quarts in the pasta pot.
The reason for choosing this particular carafe has more to do with the wide range of contaminants it filters, both chemical and organic. I also like how quickly you can filter a pitcherful---just over 1/2 minute. There's no waiting.
I recently bought the Zero Water pitcher. I like the taste of the water, but the tank you put the water into doesn't hold much. It has to be refilled numerous times to get a pitcher full, which is a pain when needing a gallon to make my iced tea. Wish I'd known about the Clear 2-0, as it would be much more suitable.
