supersurgilator
I have been doing a little research and I have found that Frigidaire only regulates the hot setting to 100 degrees, warm and cold are normal, whereas Whirlpool regulates everything.
Also I have been wondering, is this temp. regulation taking place in the water value, or the temp selector switch? Would it be possible to install a replacement valve from an older machine to get true temps and not the regulated ones?
