Welcoming the Westinghouse Washer
turquoisedude
Aug 8, 2007
10,564
So, that 1950 Westinghouse Laundromat from Tampa that was posted here arrived in Sherbrooke, Quebec last week. I blew off work on Friday afternoon to pick it up.
I have absolutely no idea of what model number it is, though!
I couldn't find a name plate anywhere inside or outside...
It's a pretty simple control dial and it has an ajustable water level control. The dial and the name plate are a maroon finish - could that help indicate what model and year this is??
It wasn't so bad...
The tub seemed to have slipped out of the framing on the sides (I think they called them 'snubbers'). With hubby's help (yes, he is still speaking to me and I have not been thrown out), the tub was at least re-seated. But something tells me there are screws or bolts missing - the top right side of the frame seems to be crying for a bolt to anchor the tub... Any thoughts???
Doesn't that timer motor look familiar?
I'll be darned - just like the 56 GE Washer and Dishwasher! Hope this one still works... I am going to need to do a bit of rewiring before I try this baby out!
And it's going to need a new boot....
As you can see, the boot is totally shot.
I am launching an appeal to anyone who might know what model this is so that I can start my parts hunt. I seem to remember hearing that the boot from the 80's Westinghouse front-loaders might work. I am always glad to hear from anyone who's more experienced with this type of machine than I am!!
I have two WCI - FL machines....
.... from the early 90's (I'm pretty sure they are cosmetically the as the 1980's models) and the tub and door openings are oval rather then round, so I don't know they would work, but I am not a Westy expert.
I can post pix later today if you would like.....
Kevin
Paul, I'm sorry for the delay..........
This is the only decent photo of the boot / seal I could find. I will take other photos for you, just let me know what (angle, view, etc) you would like.
I can also give you measurments also. E-mail me if you'd like and let me know.
Kevin
Paul, have you offended the electronics Gods?
What is it with you and those pesky timers? Are you really trying to tempt fate with the "I sure hope this one works"?
LOL!!!
Still, I have hope for you, yet. If you can pull off the Kitchen like that, this washer should go well for you.
Congrats!
RCD
Just like that "somebody up there must like me" cu
Yeah, I should learn when to keep my big front-load mouth shut!! lol
Thanks for your good wishes, Andrew!! Do share when you complete the transaction on your dream machine!!
They're calling for rain Sunday, so guess what I'll be working on...
Door Boot
I have a new door boot for the Space Mate westinghouse, I don't know if it would work or not, Maybe someone like Greg would know, If you need measurments let me know!!
Kim
And some sad news about the Westy...
Yep, should've kept that big front-load mouth of mine shut... The timer motor in the Laundromat is dead! AAAARGH!
Still, if I could find one for the GE, I think I should be able to find one for the Westy.
What a neat find! The model # plate should be on the toe plate-
I have used a newer style boot on my slant fronts, but I still need to figure out a better way to attach it to the outer tub-
The only difference I have found on the boots for the space mates & the ones for the regular machines is the lip on the space-mate boot part that the door closes against seemed to me to be a bit smaller- it's usable, on a regular westy, till you over suds it- the water drools out at the bottem of the door a small bit- looks like you will have fun -I love my westys!
The SpaceMate boot (Q-4689) won't work, I think it's too small. The Q-4688 boot for your washer are rare as hen's teeth and likely brittle and useless if you do find them. I used a 80's WCI boot, now NLA but still around at many parts companies. It works just fine but that lip on the outer rim makes it hard to close the door. I trimmed the lip off of my boot and it's much easier but this must be done very carefully as it has to be perfectly smooth to seal against the door-glass.
The snubbers on the top of the drum should be seated on two metal plates bolted to the top frame. The side and bottom snubbers should be intact but they probably all need a good cleaning with steel wool and the snubbers themselves can be cleaned on very fine sandpaper until dull-looking. There are two springs on either side of the suspended assembly that can be adjusted if necessary, correct drum angle should be 28 degrees when full of water.
Can you hear the timer motor running - or trying to run? If you remove the timer from the machine and run it, can you hear the escapement moving? Does the timer motor run when it's removed from the escapment?
I have all the service lit. and parts info on these, they are fun to work on. To replace the boot, you have to separate the drum halves and use a large worm-gear clamp and lots of silicone to keep the boot on the drum. There is just enough room between the lip of the drum and the basket for the clamp with the screw/worm gear at the top. The fill-flume gave me a bit of trouble forcing me to remove the top weights a number of times but we'll go over that when you get that far.
This is a great machine, you will have fun restoring and eventually using it for many years.
Good point about the timer motor
You know I just tried to run it in place... I'll pop it out and see if I can hear any kind of movement! Thanks!
I still need to find the bolts that attach the metal plates to the frame - would you happen to know the thread size and length??
BTW, your Westy looks like mine and I love the turquoise laundry basket!!
I think mine is going to need repainting - is that considered desecration??
