Well...here's my Frigidaire Flair
It needs cleaned up....
but everything seems to be accounted for. I have all the knobs and it seems there was something wrong with the oven knob/thermostat because it's been removed and I found it sitting inside the top. It's a black device with a copper cable and sensor. I assume this goes down into the oven compartment, but I'm not sure how or where.....
I haven't tested it. There's no cord or anything and I need to find out where a cord would be located.
I'm thinking I might have a repair person check it out. If it's not too expensive.
Looks like it has potential!
If you have a VOM you can do some basic testing, and if it checks out try applying power to the unit. Hopefully the wiring diagram is intact on the back or bottom panel, that will be a great help.
