It's Gaffers, but what do they know or care? It's like Amanda brand; they take what they can from a glance. Then you add in factors like astigmatism, dyslexia, maybe cheap drugstore glasses and it's a wonder it's even listed.
Ditto that, Roto204. A one dial wonder with about 6 water changes, no need for signal lights you will know when it's "on". Clean/dry dishes in about 40 minutes, no circuit boards, chips or transistors. Will evidently last approx 40 years or longer. So easy to use the instructions are in raised letters on the detergent cup including loading instructions. alr2903
The late por tank DWs from HP-GE did not hold up nearly as well as the all plastic tanks the GE models had in the early 1980s. They were prone to rust problems around the bottom of the door and many more leak issues in general of the two I would take the plastic one any day if it were going in my kitchen I hate dishwashers that have slow leaks and ruin floors.
