Westy L5 - lots of progress to report!
turquoisedude
Aug 8, 2007
10,589
Finally got a high-speed internet connection at home (should work in Ogden, too, they claim) and since I am at home a lot more now, I figured it was high time to share the progress and pain (you'll see that later) with the L5 Laundromat!
First - I was challenged by hubby to get the Westy of the garage to make room for his new car...
Brackets and springs were reassembled
And I moved the refinished cabinet down to the basement. That may not have been exactly where hubby wanted me to put it, but hey, I will use this beauty one day!!
Tub reassembled and ready for a water test
It took a couple of tries to line 'em up right but I did eventually figure it out. The worst thing that I did when I quit my job was to NOT download all my archive photos to a disc for easy reference. Thank goodness I had a the CL8 sitting in the garage as a sample!!
But does it hold water??
YES!! You can imagine that I did a happy dance to see that water was accumulating in the tub. I even made hubby divert conditioned water to the outdoor tap for this test!
Tub seal dry as a bone
Call this 'pure dumb luck' - I was able to re-use the original tub seal beefed up with some flexible liquid gasket compound. Better still - it worked! Not a drop to be seen from between the tubs and the hole that I had patched up in the bottom of the tub was not an issue anymore either. The gods of Laundromats were well-pleased!!
Slight pump issue
I managed to pierce the cover of the pump when I reassembled it for the water test AND the gasket I tried to make for this was far less than a perfect seal... I figured a gasket plus liquid gasket approach was going to work here and that a touch of JB Weld would fix the pump cover.
So now it was time to mount the tub back in the cabinet
And oh my, that was trying exercise indeed! Hubby was most gracious in helping me to wrestle the tub back onto its spring-loaded supports. I would definitely recommend a two-person approach for this step!
Re-installed the timer and wiring
Compared to the GE Combo, this was a piece of cake! Oh, and I made absolutely sure that the timer motor still ran BEFORE I installed it again... It did... LOL
Now the water inlet valves
They had originally been installed on a bracket that pointed the hose connections inside the cabinet (possibly the machine once lived with a through-the-floor water conncetion). I re-installed the hose connectors through the back of the cabinet, since I may wind up having to swap water connections until I can get some permanent plumbing in the basement done.
And now for the belts and changer
These were also a bi***, er, challenge, yes, that will do, to install! Again, hubby helped me out here.
It looks good, but read on...
Power cord
I figured that 25 feet of 14/3 would do... LOL I could have used some 16/2 but I figured grounding was our friend...
The first test
I just had to record this for posterity. It was NOT the result I expected, needless to say...
I recall in a previous post that someone had pointed out that the bracket on the changer was not securely attached. This was indeed the case, but Mr.Know-It-All here figured that JB Weld would do the trick. It didn't. The good news is that I found a welder in Magog who is currently repairing the changer bracket.
OH and I found a motor repair shop there, too! These people can and will rebuild any motor! Jeb (from Mansfield, OH), email me - I think they may be able to help out with your Westy dryer motor!!
hang in there. one step at a time. trust me i had mine totally apart 3 times.. but she is lookin real good and almost there... oh cool vid.. did you say the f word? ha ha
Paul ! that sucks...but your one step closer to the wash drama right... hang in there. The machine looks great. Your efforts will be rewarded... take care.
Darren k
Turqoisedude
So happy to see your progress, i have a weak spot for westy's, yes a video would be great when you have time. I had asked in a previous post that was probably missed, but i wondered what kind of spider or arrangement is present in these westy's that they are still "good" after 50-60 years and yet many posters complain of their failure, in the new F/L's after about 5 years. Thanks for the info. alr2903
Paul, Hi there, this is Gary. Congrats on the Westy. I just talked with Darren and he mentioned that you were getting your Laundramat to work. I'll drop you a private note. Bye for now. Gary
Looking great Paul, I can't wait to see it all back together once you get the change bracket fixed. It's always something with machines this old, I've been there many times. Thanks for sharing, posts like these make the Imperial Forum so cool!
alr2903 - Westy spider arrangement
I am really not sure how this worked - I have to admit that I am fascinated at how the wash tub is suspended and supported by those heavy springs and the snubbers to keep the tub centred. Unfortunately I have no idea about the engineering behind them! Based on what I have observed so far, the springs seem to hold all the weight - it really is a unique way of mounting a wash tub! I am sure that there is someone out there who knows more than I do!!
Westies...lol
Is that your Westie, "Newman" on YouTube? He sure is SMART, love the 'yawn' trick! We have Yorkies, so far only our Boy Winston will do high five, the girls, well...isn't being cute enuf?!
