"What ever happened to the '59 Kelvinator?" UPDATE!
swestoyz
Sep 27, 2004
6,599
Cedar Falls, IA
For those who were around, you may remember back on New Years Eve 2005 I stumbled upon a Kelvinator that I ended up restoring in January of 2007. While most of the mechanical restoration went fine, there was one very small problem:
A cracked clutch drum.
One of the big issues was getting the clutch off the original 2 speed motor. I was having a hell of a time getting the set screw out. Tried everything.
I even bought what I thought was a 2 speed motor that would fit from work that ended up not wiring up correctly - that I was going to couple with a spare clutch I got from Chris. Didn't pan out.
So, this fall I brought the original motor to a buddy at work who is a master welder. He was able to get the clutch off without any issues, and TIG welded the original clutch back up! While it isn't perfect, it certainly functions much better than it did before!
While I had the clutch apart for reassembly, I snapped some photos so folks could see how it works. Pretty simple and ingenious for what it is, but I can see why it was failure prone.
It works like this:
The center shaft is bushed by two bronze sleeve bearings pressed into the outer drum. There are two clutch shoes that fit over the two 'arms' that stick out from the center shaft. As the motor spins up those shoes will glide outwards and grab against the outer clutch drum - thus a clutching motion. When I first got the machine you couldn't even spin the center shaft inside the outer drum. Now it spins like a dream and I no longer have issues with the motor start switch!
The two clutch shoes shown in the photo below are pretty thin on pad material. The spare I have is in much better shape, but I figured I'd get as much mileage out of this as I can.
Weld from the inside. Almost can't even see where the weld was. While there is a slight dip in the overall circumference of the drum, it works well enough for now. I'm lucky I even have this to use - I figured I'd have to bust the clutch up to get it off the motor.
So Ben, how's it run?
GREAT! There is still some clutch rattle that is present due to the thin pads on the shoes. It has gotten a little better after running a few dozen loads through it as they have re-formed to the new shape of the drum.
I made a video of a full wash, and posted it on YouTube (see link below). I was masking the clutch issue in my 2007 video (purely on accident) with the Cheep Trick song, so the new video does the machine justice. I'll post some more photos of the machine below. Enjoy!
