What is L&H?
If the oven floor rust bothers you or gets worse, you can always look for an aluminum cookie sheet or sheet cake pan of the proper dimensions to fit the oven bottom and it will cover up the holes and be easier to clean.
The rust in the warming oven side can be covered with high heat enamel; just have the windows open the first time you fire it up.
