What's the best cookware for coil element stoves?
Marky_Mark
Aug 3, 2014
690
Living in Palm Springs and Madrid. From Liverpool.
Hi guys
What are the best brands and types of pots and pans, vintage and modern, to use on traditional coil cooktops?
I have some All-Clad pans and this week I purchased some nice vintage Ekco Flint and Amway Queen pans.  I know the most suitable pans should be flat bottomed, but unfortunately some of these pans have bottoms that are fairly concave and they don't all make good contact towards the centre of the elements.
Mark
You might want to consider choosing cookware that is induction friendly just in case later on you want to get an induction stove. And induction friendly cookware has some iron or steel in the lower surface, so that it captures the magnetic impulses and turns them into heat.
Personal note: I just took a magnet to my favorite cookware and only the cast iron stuff is induction ready. Shoot!
Rich, I totally agree with you. About 20 years ago I wanted to replace my Farberware cookware(I should have just kept it) with either Calphalon or All-Clad. I invested close to $1400 in replacing everything I had in Farberware to Calphalon. Now I love them but when I switch to induction I have to replace them all.I'm thinking of starting now and replacing what I use a lot one by one. I purchased A "Made In" pan and really love them.
Best cookware for conventional electric cooktop
Needs to be flat and be reasonably heavy.
You can test the cookware for the suitability on your coil top range by putting an inch or two of water in it set the burner on high and boil some water when the water is getting close to boiling lift up the kettle, you should not see any red underneath it in an ideal world.
In reality there may be a few small spots of red, but if even a third of the element is glowing red, the pan should not be used especially at a higher heat.
It will damage the element, possibly causing the element to fail violently , it can be dangerous to the cooktop the user and the pan to let an element be red hot underneath the pan.
John.
I've tried the Amway Queen, Wonder Ware (mom has a set of this she bought in '67) Montgomery Wards, Sears etc.   Ecko, West Bend & Regal made many of these in lots of variations for different sellers' brands.  Many will work on induction, but sensors on ranges vary so it can be hit and miss. I hear Samsung induction pan sensors are bit more sensitive and much of this cookware won't work at all.   I used some of these Regal-made pans for a while, found they were a bit thin compared to the All-Clad I was used to.
All-Clad Metalcrafters has an outlet store online and periodically has sales events with big discounts on damaged package, seconds, etc.  You have to sign up the emails and while you'll get occasional sales notices, watch specifically for the factory sale and clearance.  I've bought pans and cookware through these events several times, huge savings to be had.  You may not find all the pieces you want on the first go, but another sale will be coming soon enough.
This link is to their customer service page, scroll down and enter your email address to sign up for the notices.
Tuck a magnet in your change purse and test the bottoms of pans before buying to see if they are magnetic if you are buying for induction. Flatness of the bases in induction cookware is not as important as it is for regular electric elements.
I think the new Farberware pans with the aluminum base sandwiched against the stainless steel pan with another layer of stainless steel to hold it very flat should be good for use on an electric element. Farberware skillets flattened against the element very well, but water in a pan like a sauce pan or stock pot prevented the base from getting hot enough to flatten against the surface unit.
Almost all of my pots and pans are Classic Farberware SS, the newer version from the 90’s with the aluminum core sandwiched between two layers of SS. It is excellent, and worked well on my previous coil top and works equally well on my new smooth top stove too.
I tested it with a magnet and it won’t work on an induction stove, which is fine with me. I have no intentions of buying an induction stove any time soon, if ever. I’m perfectly satisfied with my radiant smooth top.
I also have two Cusinart non stick frying pans and they also work great on either a coil top or smooth top.
Eddie
About that "magnet test" . . .
Our stainless steel bowls fail the magnet and flat bottom tests but they'll heat up on our Frigidaire induction stove.  Is it possible Electrolux is using something similar to Panasonic's Met-All technology?
We don't have any aluminum or copper cookware to test.
I wouldnt trade
That Amway Queen, or any other waterless cookware sold on home demonstration IE Saladmaster, Townecraft, Vita Craft etc for all of the others I bought a bunch of All Clad on recommendation of others and ended up giving it all away, its miserable to use and the hardest thing to clean ive ever used.
"That Amway Queen, or any other waterless cookware sold on home demonstration IE Saladmaster, Townecraft, Vita Craft etc for all of the others I bought a bunch of All Clad on recommendation of others and ended up giving it all away, its miserable to use and the hardest thing to clean ive ever used."
Sorry, not clear to me which you prefer:
1) Amway Queen (Saladmaster, Townecraft, Vita Craft)
2) All Clad
ANY
Of the cookware sold on home demonstration is basically made the same, Most all of it is made by Regal, any of it is my favorite I use Townecraft I do NOT like All Clad, the handles are uncomfortable , the metal spots and is terrible to get shiny, andthe lids set flat like restaurant cookware so when a pot simmers it spits all over your stovetop, ill keep my 45 year old 5 ply Townecraft, the lid sets down inside a lip so it minimizes spatter and forms a seal
Thanks for the help and advice.  I have used gas and induction almost all my life and I have little experience with anything else, until now!
Some of my pans make fairly good contact while others make very poor contact.  I have also bought a couple of other elements to try and it is no better.  Here are two photos I took immediately after lifting up the All-Clad frying pan pictured above -- terrible contact.
I had never previously even thought about this issue, as it is of no concern whatsoever when using gas or induction.
Re:#15
Mark, the pan you ordered is exactly what my 4qt. Farberware pan looks like. I love these pans! I had a complete set of copper bottomed Revereware before I switched to the Farberware. I like the Farberware much better. They heat fast and evenly and are easy to keep clean and shiny. I use Barkeepers Friend to polish them.
Theres lots of this cookware on eBay. Search for Farberware Classic SS. I prefer the older version with the SS lids, not the newer version with the glass lids. Glass breaks, SS doesn’t so the older version is more durable. The really older version has aluminum bottoms rather than the sandwiched aluminum core with the SS base. I have just one pan like this, a 1 1/2 qt sauce pan which is a rare pan. It is fine, but I do prefer the newer version, but I also like the particular pan size too.
Eddie[this post was last edited: 2/20/2023-11:58]
