I'm trying to help a friend with a Whirlpool 27" dryer from the later 1990s. It's the one with 4 rollers and the lint filter below the door. The dryer keeps overheating and blowing the high limit thermal fuse on the side of the heating element. I've replaced the high limit thermostat & fuse twice, the cycling thermostat has also been replaced, and the thermal fuse on the blower housing is good. The airflow is strong and unrestricted on a short vent line to the outside and the outside vent is free & clear. The dryer is squeaky clean inside, and there is no blockage or odd noises.
What could it be? I can see the heating element cycling on and off like it's supposed to (the back portion glows but the front doesn't. I assume it's because the cold intake air at the front of the intake cools the nichrome element so much it won't glow.
Maybe it's placement of the fuse. Does the high limit thermostat mount toward the front and the high limit thermostat behind it, or vice versa? Right now, the fuse is in the back and the high limit thermostat is in the front.
Assistance is much appreciated,
Dave
Dave
