Whirlpool dreamspace fl washer
spinspeed
Silver Member
Oct 4, 2009
235
Far North New South Wales Australia (originally Lo
This is an amazing washer, but no recirculation. When filling the washer sprays water directly on clothes with the additives.
Thanks for that Brastemp. I did notice a port in the rubber seal of the door and thought it was for recirculation or as you say it runs water and additive directly from the soap dispenser during fill. My mum's very old Bosh FL does that.. I may still consider buying it or I may go for the big Samsung FL. decisions decisions.
Its much cheaper than the list time they were on the market, the Retravision catalog today has them listed for $1400, thats incredibley cheap compared to the $2500 they wanted for the Neptune when it was available.
I just wish Whirlpool would post a proper manual on the website, so it was possible to see how the cycles worked.
whirlpool
wuhrs machine ewer thedrum is tilted and it has some very spesial paddels that tangels ewerything it is a nigth mare when it is done
I have one.
No problems washing or rinsing but the final spin can take a while. I tried to make a video of a large load but it was useless since the entire final spin took 27 minutes because of the balancing. It always does fine on the interim spins between the rinses but before it revs up to 1200... it tries to balance to perfection. *oi* It is very, very quite, though and, yes, made in Germany.
You get two manuals with it: one how to use the machine and one cycle chart. Even though the cycle chart is only two pages, it tells you everything to need to know. Of course, you can still sit there with the washer and watch it... as I do.
BTW: the rinse modifier does not add more water to each rinse as you might think from reading the manual; it adds more rinses (Normal = two, Intensive = three, Sensitive = four). The Jeans cycle is labeled Baby Laundry in France and is suitable for sensitive skin ( -> it uses the most water at 120 liters for a full load). I use it for sheets and pillow cases.
Alex
