My neighbor across the street had a Whirlpool WED5700VW0 dryer on her curb when I came from home one day last week. It looked really clean and so I hauled out my appliance cart and brought home a new project. I called my neighbor up and she told me that it was taking 2 hours to dry a load of towels so she bought a new one.
After bringing it home I opened it up and found the blower wheel completely plugged with lint so I figured it was an easy fix to get it running properly again. But then I saw a blackened heater element caused by a cracked ceramic insulator. While the heater element still tested OK for continuity, I bought a new one anyway and put it in on Friday.
On my first test run, I noticed that as soon as I turned the timer to the AccuDry sensor drying Energy Preferred position, the timer motor started ticking immediately even before I pressed the "Push to Start" button. The dryer performed the cycle well and dried the mixed load of clothes in 30-35 minutes on the Medium heat setting. The buzzer went off, and despite having the Wrinkle Shield set to Off, the timer motor continued to run once it reached the first AccuDry Off position. It continued to tick and advance the timer until it reached the Wrinkle Shield 30 minute Option Off position at which point it finally stopped ticking and advancing.
I then noticed that the timer motor will tick with the dryer not running when the timer dial is positioned anywhere but an Off position. When the Wrinkle Shield dial is set to Off or the 30 minute option, the timer motor will also not tick when the timer is positioned in the Wrinkle Shield 90 minute option zone. When the Wrinkle Shield dial is set to 90 minutes, it will tick with the dryer stopped and the timer dial positioned in the Wrinkle Shield 90 minute option zone.
When the door is opened, the ticking stops but continues as soon as it closed again.
I took the timer apart and all the contacts appear to be clean with no arcing or corrosion present. Continuity tests on the "Press to Start" and Wrinkle Shield switches were successful and they seem to perform properly (i.e. "Press to Start" button starts the button and the dryer doesn't intermittently tumble in the 30 minute timer zone when Off is selected, it will tumble intermittently in the 30 minute timer zone when 30 minute option is chosen and likewise when the 90 minute option is chosen.)
Another weird thing: when the timer dial is in the Wrinkle Shield zone position, the timer motor is ticking away but no tumbling is occurring, you can manually move the dial back into the AccuDry or Timer Dry zones and the dryer will start right up without pressing the "Press to Start button.
I checked all of the wires for loose or wrong connections but couldn't find anything amiss.
In the attached photos I have included the wiring diagram. I am no electrician, so I may have missed something from the diagram.
I am a vintage Maytag man and this was my first "modern" Whirlpool dryer. Can anyone tell me if this is normal behavior for this dryer and if not, what I may have missed in my testing?
Thanks - Jeff
Thanks - Jeff
