Whirlpool Imperial 70 Washer capacity?
alcove
Jan 9, 2017
3
Oneida, NY
Does anyone know the capacity of the Imperial 70 washer?
I need to replace, possibly w a SQ, but I don't want to downgrade capacity. Actually, increased capacity (king size bedding) is tempting me toward a TL HE machine, but i'm reading terrible stories about new washers.
I'm told that the transmission is failing and the part is not available.
And, if anyone here thinks I might salvage it... We bought the Imperial Seventy set new in Oct 1986, and the washer has just developed a loud, intermittent knock under full load in the agitation cycle. A video of the washer in action linked to this post. All else is working fine under a lighter load.
Over 30 yrs of uninterrupted service.
Thanks
http://https//www.youtube.com/watch?v=nMA_www5XN4
Capacity Of A 1968 WP Washer
The tub held approximately 18 gallons of water on hi and this washer could easily wash 9-10 pounds of heavy cotton clothing.
A new SQ TL washer can wash 12-14 pounds, your best bet for capacity and durability would be a SQ FL washer which easily wash 20 pounds.
1986 WP Imperial 70 Capacity
Thanks Combo52,
That's very useful info re the SQ. I might go that route. I don't know if your reply title was a typo, but to clarify, this is a 1986, and also described as a "Heavy Duty" and "Super Capacity" machine. I gather the capacity is higher than some other models.
Thanks again,
Pete
Thanks Combo52. Again, that's very useful info.
After watching the video, someone commented that it's the spring on the tranny. Sounds like a greasy job for me, but not out of the question.
Cheers,
Pete
Imperial 70 was / is a great washer
I love that washer. I had one from 1986 too. You could wash anything in that washer and it would come out without any flaws.
Quiet and dependable. Until your brother throws a sleeping bag in there one day....
I think PhilR posted a video quite sometime ago about a similar problem he had with a Inglis (Canadian Whirlpool) belt drive he picked up. If I recall correctly it was something pretty straightforward.
If it is indeed the transmission spring its not as daunting as it sounds if you are mechanically inclined and can find the part.
Good luck!
Broken Transmission Spring In A 1986 BD WP
This is likley the problem, BUT they break because the transmission is full of water and the springs rust and break.
From the rear of the washer you can push a pipe-cleaner into the breather hole on the top center of the transmission and take an oil sample, if it is rusty or white and murky you have water in the gear case. To fix this you need a new agitator shaft and spin tube and a washer at this age will need a hole lot more as well. Outer tub rust is a big problem on these machines at this age.
In any event you probably have a BIG project on your hands, parts can be found on the internet however if you are inclined to try fixing it.
Thanks!
Thanks to everyone who posted here. Your kind input helped me to make an informed decision. Regrettably, I'm not up to repairing and maintaining the old Imperial 70, so we purchased a new Speed Queen.
Kudos to you all who are saving these great devices from the land fill.
Cheers,
Pete
