Whirlpool Pair
Lower-end washer.  Two water levels.  Regular, Permanent Press, Gentle or Short or Soak?  Probably 1-speed.  May be intermittent agitation if a designated Gentle cycle.
Dryer is a bit more deluxe.  Three cycles, so probably Timed, Automatic Regular, and Automatic Permanent Press (both thermostatic-auto).  Separate temp control, probably High, Med (or Low), and Air.
