Whirlpool Powerclean nozzle cap question
user 2984
Nov 20, 2012
730
I wanted to know if the two white tabs inside the black rubber pressure cap need to line up with that straight line in the pump outlet? There are zero directions anywhere online about putting this cap on and I want to make sure it’s installed correctly. Does it matter if those two little white notches aren’t centered with that line?? Or are they supposed to be center?? When I screw it on tight it doesn’t line up.
Reason being that the upper arm has very low water pressure and I’m trying to find out why. Thanks a lot for all the help I really appreciate it!
    961.6 KB
    1 MB
