ryner1988
My washer (model number above) has started having a problem where the auto sense function doesn't seem to be working right. It no longer does the pulsed tub spins at the beginning of the fill to determine water level on any cycle. In normal operation, the washer fills to a small load level while spinning the tub every few seconds. Then the fill stops and the sensor determines if more water is needed and adds the appropriate amount. Now, however, it just fills to the top regardless of how full the load is and no matter what cycle is chosen. I do not have deep water wash option selected.
I have run the calibration sequence on the washer and still the issue continues.
This problem in itself honestly isn't a very big deal as I normally wash full loads anyway. However, I just want to make sure it isn't indicative of a larger problem down the road. I remember a couple months ago the machine wouldn't spin in the superwash or heavy duty cycles, and a recalibration fixed that so I let it go. However, this new issue makes me wonder if the control board might be going out. Is the auto sense function part of the control board, or is that its own component? Is this worth calling someone to come look at the machine, or should I just use it as is? It works great otherwise. I just don't want the control board completely taking a crap one day, but I also don't want to pay someone to come out to look at the washer when this is such a minor problem in my case of hardly ever washing anything but full loads. My warranty expires in a week.
As always, thanks all for your input.
Ryne
Ryne
