Buying a new machine right now is not an option I'm on my third front loader in seven years, the first was a Neptune that worked so well I could use non HE detergent with excellent results, until I had a flood and lost it.The Neptune that replaced it was only good enough to fill with plastic explosives I had that much trouble with it so I bought the Duet.
My water is really soft and I have had problems trying to use a liquid with any amount of good luck so remain with powder detegent(s).
As for the rinsing the Duet I have only rinses twice unless I add an extra rinse to the cycle, so when I have trouble with rinsing I usually set it on another rinse by itself, I find it uses more water and it solves the problem.
So between watching the detergent dosage more closely and a manual extra rinse I may have the solution.
Appnut recommended the white cycle, so I tried it again without the extra rinse in the cycle and it faired much better than the normal cycle, so I guess I can use both White & Heavy Duty for better results, these two cycles seem to use the most water with a decent wash time.I think that the exra rinse programmed into the machine on the White cycle seems to have voided the first rinse so I modified the program by taking out the extra rinse and it worked better,much better, who knew??
Maybe down the road I can get a Huebsch or Miele, so I'll persist for the moment.
Tks everyone.
Cheers
