I never payed much attention to them despite being a Maytag fan, and while I admired them, they seem to have a reputation.
Looking back and comparing them to European/South American front loads I think they could have done several things differently. I also think they could have simplified the machines.
1) why didn't they consider a hose which connects to the top of the tub to a vent in the back?
2) why the re-circulation pump?
3) Why didn't Maytag use a 2&18 pole PSC motor which would eliminate the complex control board? {Let the timer cycle two contacts to reverse tumble. Another for spin in series the pressure switch (water drained out), door lock, and off balance switches.}
4) Why not a glass door?
5) why not a user front serviceable lint/coin trap?
6) Why not a BOL or entry setup? IE, is ATC really needed?
7) copy of the euro suspension system found in 70s machines?
I think Maytag didn't do enough research and did things to inflate the cost of the machine without adding any value to them. A simplified low cost machine would have drawn in more customers and made for less problems down the road.
