Will this make a great donor for an A407?
It will work although it isn't a low mileage machine by the looks of the inner tub. $125 would be too rich for my blood just to cannibalize.
I figured on emailing the seller for his best price. My tub is getting a few rust spots at the drain holes plus the machine has lots of use on it so I figured to use this trans after a cleaning and oil change and nylon gear replacement. Then maybe sell the timer and misc parts to recoup some of my money
if it has the pitman style trans?
Yes. Orbital trans models have the shark fin agitator
Price is high but I never haggle via email, good way to get a seller to ghost you. Asking if the price was firm is about as far as I would push it.
Better to go in person, check it out, politely make an offer and explain why if they balk; age, condition, wear, etc.
Almost always works for me as the seller usually wants to get rid of the machine and doesn't want a potential buyer driving away over a few bucks.
I don't know if the machine is still connected as it appears to be in the pictures, but I agree that it's best to check it out in person to see how it behaves, then make your offer.  I got my '87 A712 (old style transmission) this way a few years ago for $75.   Dan makes a good point about how much you'd be paying at full asking price for a bunch of used parts.
Dan, what problems do you see with the inner tub?  It looks gray rather than white to me, but other than that I don't see any signs of deterioration.  I respect your good eye when it comes to all things Maytag, so am curious to find out what you've noticed that I haven't.
The tub itself looks ok but the shiny glaze has worn off. It has average wear for its age but $125 is steep unless it was driven to church on Sundays by an old single lady. Also remember that the top half transmission of 12 series washers are only compatible within the series. Older pre 12 series transmission tops will not swap over if there are bearing/shaft issues.
value of that machine without insulting them?
$50 bucks would be my starting offer.
Perhaps a few bucks more if very clean inside and out, i.e. no rust, oil or water leaks, scuffs, chips, dents, etc.
The dull tub gloss might be a hard water situation. If buying specifically for the inner tub it may not be the best donor candidate. But the photos suck, could be just under exposed.
However, if you get it cheap enough could be worth it for parts. The agitator alone would fetch at least $50 on eBay.
" Older pre 12 series transmission tops will not swap over if there are bearing/shaft issues. "
So I should prob use the top half of the good trans I have from a 1964 A500 on mine instead and just look for a clean rust free spin basket and pass on this one?
