Amana ABB1924BRW05 Fridge door opens too far
weed30
Aug 23, 2010
163
St. Louis, MO
Any secrets to fixing this issue? I raised the front fridge feet which helped if I only open the door about 45 degrees, but any more than that and the door swings completely open. I'd like it to stop at 100ish degrees. I thought about adding shims under the front of the fridge but I don't know that running a fridge that's not level from front to back is a good idea. Let me know if it's ok to do, or if not I'm wondering if there is something I can attach or add to the door stop or the metal piece so it stops the door sooner.
This seems to be an issue for a lot of newer fridges - why not make an adjustable stop?!! I didn't have this problem with my 2006 GE bottom freezer fridge.
Picture of the door stop when fridge is closed and open attached.
    26.2 KB
    28.7 KB
That often happens when the plastic cam on the bottom hinge pin wears out. The OEM stuff lasted a decade or more, the replacements only seem to last a few years. I've tried a few different manufactures, no difference, but at least they are cheap.
I got this refrigerator 2 months ago, and it's just me so it doesn't get opened/closed a lot. I'll check the bottom hinge pin, but many people complain about this issue so it's the dumb way it was made.
I think I figured out a fix - I have a thin piece of metal that I'm going to fashion into a better stop. I'll drill a hole in it so I can attach it to the pin. I'll post pictures if it works.
