Gas ranges with electric broilers
hvtech42
Sep 23, 2014
89
Massachusetts
I'm seeing the latest gas ranges out from Whirlpool, GE, and Frigidaire have switched to using an electric element for the broiler. 120 volts of course, as is standard for gas ranges in the US. I saw a service bulletin from GE warning that these ranges need pretty much the whole 15 amp circuit, so, unlike old gas ranges, risk tripping the breaker when sharing with another appliance. Still, that limits you to something like 1500 watts for the broiler, which is pretty anemic.
Granted, the standard tube-type gas broilers (non-infrared/Ultraray) that came on these ranges before, were pretty poor performers themselves. So the question is, for those do more broiling than I - are these 120V broilers a downgrade, upgrade, or lateral move when it comes to cooking performance compared to the old gas broilers?
Basic gas ranges without self cleaning ovens.
The electric broilers are being installed in some of these cheap ranges because it’s much cheaper than putting a separate gas broiler in the top of the oven.
Most users don’t use a broiler at all. A lot of people don’t even know what a broiler is for range manufacture started leaving out the broiler pan and grid 20 years ago on many ranges
I imagine these small electric broilers May broil OK but they broil over a much smaller area, it’s kind of a shame even though I like electric ranges better. The gas broiler on a gas range was one of the few advantages. A gas range had over electric because the gas flame would consume the smoke from broiling
The manufacturers do not want to build a gas range that requires a 20 amp 120 V outlet because that’s a different type of plug and these cheaper ranges are widely used as replacements for older gas ranges.
I’ve always thought of a shame that true dual fuel ranges did not catch on in a bigger way in the US. They’re cheaper to build, and there are a better range overall, the only thing better was an all electric range, of course.
John L
Clearly would be a downgrade from what's stated, if it's breaking tradition from the apparatus it has long-worked and long-had....
I burned a lot of bacon using that broiler up there, caused a lot of fires that extinguished themselves or doused with baking soda, I over time had to clean and clean til all residue was gone from...
I like to broil with my gas oven, and like probably like the same things that could happen with an electric, should merely be done responsibly...
And in my case, live and learn, and replace that knob over that very part of the oven that a small portion melted from, or live with the idea that the damage is fairly minimal and it can at least turn and it's for the seldom-used middle burner on my cooktop anyway...
So far, my daughter has never broiled anything, she's mostly a baking girl and cooks on the front two burners, a regular on the left and often the power-burner using freak like I mostly am even occasionally for things that don't need that much heat but regulate it well enough on the right!
So I look at this as cheapening needlessly--a Downgrade...! And of course if a gas range, needing 120V only for a few small things such as a clock, timer, self-cleaning or just a thing like an electronic ignition, then putting 220V for broiling just seems unnecessary...
Gas ovens with broiling should just be gas, or just go electric for both... I had no idea that anything like this was even practiced, or any ranges out there were being built like this... Just until now, unaware...
-- Dave
That's been a thing for many years now here in Australia; I currently have a Westinghouse 625 "stove" (range) with natural gas cooktop and oven, but electric "griller" (broiler)
I find the electric griller slow to heat up, but once it's reached temperature, it'll burn everything within 1.5 seconds lol
Yes! The Frigidaire 24"/60cm wall ovens here in the US are now made in Australia (probably in the same plant as your Westinghouse) and I noticed the gas ones had this same setup as well.
A 120 volt broiler element in the oven is like a toaster oven. Lower BTU than a gas burner? Just make the entire oven 220-240 volt electric like a dual fuel range. More efficient. I also don't see why GE has a few electric oven ranges with gas assist.
If it's an Electrolux brand, then the Frigidaire may have been manufactured at their "Cooking Plant" in Adelaide, South Australia. They used to make dishwashers and top-loader washing machines here in Adelaide, possibly compact dryers too iirc? My mum bought a Simpson Encore 756 (hence my username lol) direct from the factory through a friend who worked there, round about the time Electrolux acquired the brand; 1998-99ish
afaik Electrolux own Frigidaire, at the very least the rights to the Westinghouse brand, Kelvinator, AEG, Chef, Simpson and Dishlex
Yeah it's definitely the Electrolux connection. The 24" ovens are mainly a replacement market here - you don't tend to find them in new kitchens - so as demand for them has dropped over time, manufacturers have moved to sourcing them from abroad, where they're a more common size. Electrolux must have just searched all their plants across the world for a 24" oven that was most similar to the previous US models and settled on the Australian plant. Whirlpool did similar a few years ago - discontinued their American made 24" ovens and started sourcing them from their plant in Italy (which I guess is now part of Beko) instead.
Here's a news article from a couple years ago when the Adelaide plant started exporting to the US - looks like they're making a high end 36"/90cm range for the US too which I did not realize. Seems to have been relatively big news in the local business community: https://www.applianceretailer.com.au/electrolux-exports-first-frigidaire-ovens-to-us/
Looking more into it, this is the last appliance plant in Australia, and it seems there was a question whether there would be enough demand to keep the plant open after a contract to supply public housing with the South Australian government expired a few years ago, but the plant ended up being saved by this export push. I'm glad we in North America are doing our part to help keep Australian appliance manufacturing going! Since our population is so large, even small segments of the market here like 24" ovens and 36" ranges can add up to a lot of demand.
Yeah, iirc they kept a very basic version of a Chef stove design in production specifically for older SA Housing Trust (public housing) homes; newer properties built from 2000ish-onwards have a nicer looking, separated cooktop and oven built into the kitchen cabinetry, which look the same as ones private homeowners can buy for their kitchens. I have a friend who lived in an older housing trust with the Chef stove, but now lives in a newer one with a better cooktop and oven.
We thank you for helping to keep our cooking factory going! Most of our manufacturing jobs have disappeared in the last 25 years, including the laundry and dishwasher division of Electrolux, GM Holden, MMAL (Mitsubishi) and Hills Industries, to name a few. I know this means a lot for the employees and their families who rely on the factory to put food on the table and a roof over their head. Fingers crossed we can stay competitive in spite of a volatile economy right now.
I get why demand would have been slowing down for the domestic market though - the Adelaide-built cooking appliances last forever! This Westinghouse 625 gas stove with electric griller has actually outlived the previous Chef "Diamond Re-ignition" all-gas stove it replaced, which only met its demise because my mum accidentally set the whole cooktop on fire while cooking in a wok! Luckily we had a fire blanket nearby, and I've always made sure there's one by the stove ever since!
4080.jpg The trusty Westinghouse GSN625S in all its glory!
Fascinating! I was at GM in the US during the death throes of Holden----wanted a Chevrolet SS but never could quiiiiite pull the trigger. We tried to launch OnStar down there (as part of their Holden v2 import-only strategy--trying to show technological leadership) but the failure of the Commodore wrote the death-knell for the entire effort. Lots of smart folks laid off...the small launch OnStar staff was recruited from outside industries so kind of sad that they gambled coming to GM.
Honestly, pretty much the only people who bought the Opel-built Commodore in SA were the police force, state government agencies and rental car fleets, with a small number being bought new by private buyers. You tend to see a few more privately-owned ones these days, as fleet operators have now started selling them off cheap to the public and replacing them with Kia vehicles (as is the case of SA Police) or hybrids and EVs
Closure of the Holden plant in Elizabeth South left a bitter taste in enough people's mouths, unfortunately. Although I feel they may have done better if they had started manufacturing their top sellers by then, like the Captiva, Trax and Barina.
Wasn't it Australian parlaiment that ended the subsidies for the entire auto industry? They've all closed. GM, Ford, Toyota, etc. all said it just wasn't going to be profitable anymore. Did the Holden Cruze sell very well? It's been discontinued by Chevrolet too. I still see GTO's, G8's and SS's as well as sold to the public final Caprice {Statesman) police cars. Anything that Ford, Holden, or Honda and Toyota built down under would outlast any Kia/Hyundai. Our parts yards are full of them with blown engines and trany's. Electrical problems too. Buyers buy them because they are cheaper, but not in the long run. In fact, a nice loaded one isn't that cheap.
Apparently New Zealand was not quite so anti- the Opel built Commodore. That said, with GM selling off Opel to Stellantis during this period it would have not really mattered---there wasn't much future for RHD GM vehicles unless Australia/NZ went gaga for them.
We have a Buick Regal TourX (Commodore wagon) and have been pretty happy with it, and everyone wonders why it didn't do well in the US either. Issue was that it (and the Commodore) were planned as world vehicles to keep the Russelsheim plant fully occupied, and when that plant got sold to Stellantis presto--there was no business case any longer for the vehicles.
A single Thailand plant wasn't going to do it for a reasonable RHD GM offering for Australia/NZ (do not think that the Korean or Chinese plants did any RHD; one North American plant did have RHD capability (for the Equinox/Acadia, as I recall) unless Australia went absolutely nuts for GM in 2018....and they didn't.
e
GM South Africa could have built them but I don't know if they only do pickups and utes or a crossover SUV. Given the population of Australia still under 40 million, they never sold a lot. Even if 75% of them drove. Holden's best year was 1971 with 191,670 units produced. A lot considering the competition with Ford, Chrysler/Mitsubishi, and Leyland which built a V8 sedan. Not so much when Chevrolet was building over a million or 60 an hour with 9 plants for B and C body cars, not including Oshawa Ontario Canada. My source is the GM 75 year anniversary book with production numbers through 1982. After that, even the US began losing market share to Japan, if not sooner.
That was one reason, in a myriad of reasons, why Australian automotive plants shut down. I grew up and live not far from the Holden plant; I know a lot of people who were directly and indirectly affected by the closure. We live in what was already a low socio-economic area, and has become even more so since Holden closed. We haven't quite come back from that yet as a community. I'm not saying that's GM over in Detroit's problem, but seeing and hearing what I have, I really do understand locals' grievances.
Although I have noticed since then, the government on state and federal level have really been pushing STEM in our schools, so we'll see what the future holds! Elizabeth could become the next Silicon Valley perhaps? Who knows?
e
During the late 2000's-early 2010s, Holden were sourcing all but one of their RHD imported vehicles from GM Korea, formerly known as Daewoo (exceptions are the Holden Rodeo and Colorado, both made by Isuzu). Before this, Opel and possibly Vauxhall were supplying Holden with RHD imports, starting in the mid-90s. They resumed importing from Opel in 2015ish, shortly before domestic production stopped, while also souring from Daewoo. Korean Holdens were a bit cheaper than their Euro counterparts, but weren't nearly as nice to drive, in the beginning performed much worse in ANCAP crash testing and were only just a little more reliable than Opels, which really weren't designed or tested for our harsher climate.
Ford did the same thing; discontinued their mostly Mazda-based models and replaced them with Euro models, starting with Ka. After their domestic production stopped, only then did they begin to sell US-built Fords here alongside Euro Fords, which seems to be working for them as they're still in business?
