Thor Automagic transmission locked up
adam-aussie-vac
Dec 14, 2017
1,055
Canberra ACT
Hey guys, so I recently got my new Thor automagic home and the transmission seems a bit locked up so do you guys have an idea of what I can do to try and get it to free up? I do have two of them so I’ll have a better look at both of them on Wednesday as I’ll be heading out of town tomorrow.
The machine was stuck on Dry when I had it, and the control cable broke. I’m hoping it’s similar to a bicycle cable so I could probably see if I can get a replacement made or what, I’m not sure.
    3.3 MB
    3.4 MB
probably severely congealed grease or oil is the cause-could put in gasoline or diesel,let it sit a few hours,then start working the pulley back and forth till it starts to rotate.
Alright, I’ll try taking the Pump off when I get home today and consider considering this thing still has its water seal and tub bumper ring according to the parts manual so I’m kind of a bit unsure if I can just unbolt the tub and undo the tub to Pump hose
Also, I’m a little curious. Does anybody have an idea as to how I could fix or replace these driving cables? That way I could actually get my machine being able to shift from Wash to spin and back again.
    2 MB
