Amana Wringer Washer
Skooter125
Member
Jul 13, 2025
14
Greetings,
We are new to the forum and have acquired an Amana Wringer washer (model TWA202). It’s works great after cleaning and lubricating and a new belt. Some of the working parts are labeled SQ.
The rollers are cracked but are not missing any pieces rubber. But still, I am trying to find replacement rollers and hope there are some options out there for replacing, adapting, or resurfacing?
I am also trying to find a manual for it even if it’s a SQ equiv.
Any info is much appreciated!
Thank you
The rollers were out when I took this photo so we could measure them
I’m not sure I posted the right forum but would also like to ask if anyone has ever had their wringer rollers resurfaced?
I found a few companies that can do this, but I’m unable to supply them with the original specification of the roller diameters and material.
Thanks for any info.
Depending upon how severe or deeply cracked your wringer rollers are a simple chemical "resurfacing" may suffice.
Back in day it was suggested to *lightly" go over wringer rollers with a cloth moistened with kerosene, then thoroughly wash roller in soap and water (detergent would do) to remove all traces of kerosene.
Petrol will dissolve rubber, thus a light going over with substance removes surface muck and slight imperfections by also taking off slight layer of rubber exposing new surface beneath.
Obviously more often such a cleaning was done and or performed too aggressively shortened lifespan of wringer roller, thus one did not do it that often. If wringer rollers were properly cared for and used such cleaning wasn't necessary frequently if at all.
That is a Speed Queen washer with the Amana label stuck on. This was made when both companies were owned by Raytheon. Absolutely no difference other than the label.
Yes, the motor says SQ on it. It runs nice. I have been using it but my concern is the inevitable degradation of the rollers. Thanks!
Thank you! I have emailed a company that resurfaces, but they need original diameter specs. Something I don’t have. My other concern is boxing up and shipping our one and only set of rollers to the company! It would be awful if they were lost in shipping.
I may try a small test area with kerosine and see if it will smooth out some of the small cracks. The rollers are not yet missing pieces nor are they crumbling.
Thanks everyone!
Another question for the experts! Is there a SQ model number equivalent for the Amana TWA202 model? I’m hoping to purchase a service manual and SQ are the only ones available. Thank you.
I would think any later SQ wringer washer manual will give you the information you need. These machines didn't change much over a period of decades. I believe they were sold under the Koblenz brand in Mexico until a few years ago.
They were also sold as Home Queen Wringer Washers in Saudi Arabia about 10 to 15 years ago. These weren’t available with a drain pump, but other wise looked just like any other Speed Queen Wringer washer of later production ear of these machines.
Eddie
Thank you! I just downloaded the 1967 1968 SQ service manuals and the 1967 is the closest.
Eddie
Thank you! Yes, I think Lehmans sold them but I was not able to get a reply from them. Thank you, knowing the name of those may help in getting spare roller shafts.
Hi Everyone!
Now that we downloaded two SQ service manuals, we see that lubricants are SQ brands with no hint of what type of lubricant they are (grease? Graphite? Oil?) the machine runs but it probably hasn’t been serviced in a few decades and I don’t want to compromise any moving parts with lack of/or improper lubricants. We currently have the wringer head off and what’s left on the vertical roller drive shaft is very dark and oily.
Another concern is we don’t think there is any liquid lubricant because if there was, it should have leaked out when we turned it upside down to service the motor.
Speed Queen Wringer Drive Lubricant is SQ#2723 but no clue what it is.
Same for the other parts.
Thanks for any info you can share and kind regards,
Skootz
