New Miele DW does not regenerate
mrboilwash
Jan 30, 2006
1,473
Munich,Germany
After 22 years my old Bosch decided to no longer heat the water and to be honest I was glad it did so I could finally justify a new dishwasher. (That`s the downside if you can do minor repairs yourself)
Got a BOL Miele and while it seems to be a tad louder than the Bosch I like really like it and don`t regret my decision at all.
The manual mentions a regenerating cycle after every ninth cycle if water hardness is set on factory setting.
I did not notice anything unusual at the beginning of a cycle and I think I think I`ve done more than 9 cycles so far.
One time I went into the service menu to program a second interim rinse so this might have thrown the counter back to zero again.
Then I decided to up the water hardness to the max setting which made me to believe there should be a regenerating cycle before each wash cycle, so far two cycles are completed but still no regeneration.
Should I worry and contact Miele or just wait and see for a longer time?
How exactly does regenerating perform?
It just does a very short drain and a longer one then fills and starts to wash.
    71.5 KB
When salt regeneration is needed, it will do it before the cycle begins as soon as you hit start. You can tell if it’s going to regenerate as it will start to fill when you hit start rather than drain. It will do a series of fills and drains over a couple minutes or so before the cycle begins.
Ours is set to soft/medium hardness (12°dH) and regenerates every few cycles though I haven’t counted the frequency it maybe regenerates the softener for our usage twice a month.
Might be worth keeping an eye on it and see how you go. I must say ours is very economical with its salt usage even compared to my previous Miele dishwasher, and much more so than the Siemens IQ700 that we had for a couple of years before the current one. I’ve not yet finished the 1kg box of salt which I bought when the new Miele was delivered in July last year. I also find it needs a lot less rinse aid.
How are you otherwise finding the results? I still can’t believe how well ours cleans with very little water and electricity even compared to the previous, and back then very efficient, G6000 series machine that I had before.
Another thing you could do is start the machine and then test the hardness of the water that it has filled with. If there's any hardness present, it's not working.
When I had a modern Miele dishwasher recently, I could tell when it was going to regenerate on the next cycle because it would fill the brine tank at the end of the preceding cycle. Normally the cycle would end with a drain. But if it was going to regenerate at the start of the next cycle, you could hear it filling for a few seconds before the cycle ended.
Of course it's still early days and I wouldn't worry too much about it just yet until you've done more cycles.
Ok, I´ll give it more time and keep an eye on it. Maybe it`s just way more economical than expected.
Currently it has done a 2nd cycle with hardness set on 70°dH and still no regeneration. My water hardness is only around 18°dH but my impatience made me set it to 70°dH. LOL
I find the results outstanding on all cycles even the 45°C delicate glass cycle seems to clean normal daily loads very thoroughly.
It`s still new and exciting to try out all the different cycles and in combinations like with "short wash" or "second rinse"
Not sure yet what my favorite to go cycle will be.
Though not exactly the most silent DW on earth at 45dB I find the sounds it makes much more pleasant than my Mom`s 10 years old Bosch which is more silent in dB but has a very unpleasant frequency to my ears.
I wasn`t sure how I`d like the cutlery tray because it takes space in height from the upper rack but have to say my doubts were wrong and I would never go back to a cutlery basket.
Another thing I just love on the Miele is that the spray arm under the top rack does not retain any water after the cycle is finished.
On the Bosch I always covered the bottom rack with a dish towel and then gave the middle spray arm a spin by hand to get the excess water out so it couldn`t drip on already dry dishes and leave ugly water marks.
The top rack I also find superior to the Bosch, much easier to load.
Bottom rack reminds me a bit of my AEG I had in the 1990s which is nice too but I think large items like pots and pans were easier to fit in the Bosch. But I`m still learning...
Mark unfortunately I don`t have any test strips on hand and currently also using all in one tabs, so I couldn`t even tell from the look of the dishes.
But great idea and I`ll pay extra attention to the final minutes listening for an open water valve.
Is that one of the more recent G5000 series with the filter in the middle of the sump - so like the G7000 series?
And does it have AutoOpen?
My (pretty early) G7000 has the Miele typical 2 stage regeneration.
At the end of the final rinse, my starts the fan as it drains.
If it needs to regenerate, just as they display switches to dry and adjusts the cycle time (SensorDrying), instead of stopping the drain pump, it keeps that running. It makes a short hiccup sound basically - you can hear the drain pump power is switched off and on again in a fraction of a second as it switches from one cycle stage to another.
There is flushes salt into the resin from what I understand.
Drain and AutoOpen happen as before.
At the beginning of the next cycle, usually, just as you hit start, it would immediately start draining.
If it is regenerating, the drain pump needs a few seconds to start as you hear the flow diverter move.
Then it starts the flushing sequence.
At the end of that, you get the same drain pump hiccup as at the beginning of the dry cycle as it starts the usual cycle.
Mine is set to 18° currently as well and with anywhere from 16° to 20°, with about 6 cycles a month, it doesn't even regenerate every month.
Having it set to 70° should probably trigger a regeneration every cycle basically. And if you're unlucky, it might lead to salt residue on the dishes.
If you're still in the return window, you might just ask your seller if an exchange or such might be possible.
If not, Miele service is very helpful and you should have your 2 year warranty - so no real hurry to figure that out, especially when using multi tablets.
On a tangent or 2:
LG recently launched their DWs in Germany and DAMN those are water and energy hogs.
On the max settings, they regenerate TWICE per ECO cycle - and you only have 5 settings with the top setting starting at 21° dH.
That means one Eco cycle in not that few places here could basically use as much water for regeneration as for cleaning.
And think about their Intensive cycle that uses 30 liters - that would require something like 5 or 6 regenerations at 20-24 liters JUST FOR THE WATER SOFTENER.
The Turbo cycle takes over an hour, uses 1.35kWh and more than 18l of water. Mieles (or even BSHs) equivalent cycles are faster and more efficient in every way.
They look great - but usage stats are just devastating.
And on pump noise:
As DWs get quieter the actual sound of the pump becomes way more important.
I don't really mind the sound of the BSH pumps, even in the quieter 42dB versions. Haven't heard the new 40dB versions yet in person.
But I don't mind the Zeolite fan noise either - and many think something is broken when they hear that.
With my Miele however, I found that overall noise level is much more dependent on loading. My mums Siemens sounds more or less the same regardless of loading.
And: One thing Miele allows per manual is tilting the top rack - and I don't wanna miss that.
However, even though BSHs manuals say you shouldn't, their service manuals still say you can.
Henrik, It`s a G 5110 and yes it has the filter in the center of the sump.
No AutoOpen and I purposely choose it for it`s D energy rating to still get higher last rinse temperatures which should improve drying and overall hygiene because tend to use lower temp wash cycles for dishes quite often.
There`s no fan to hear when it`s drying. Do you think it should have one?
How long is the return window at Saturn? Didn`t even know there was an option like this.
Media-Saturn (my once employer) offers 14 days of returns, extended to 28 days if you are part of their members program (MediaMarkt club or what ever the Saturn equivalent is).
If it's an online order, getting them to take the return is much more easy, the process just takes longer.
Getting a return in store (unfortunately) does depend on store and person you are talking to, especially if the appliance has been used a bit. I took *almost* every return, but you might have to do some talking.
And for the fan: Apparently not?!?
I am - honestly - shocked right now.
These BOL freestanding DWs have a fan in the parts diagram. The parts list does NOT state the fan though.
Neither does the machines page talk about SensorDrying or TurboThermic drying. Which I thought was just a standard on Miele DWs.
I was 100% unaware there are DWs without fan drying offered by Miele today.
Final rinse temp can vary a lot on higher end models by Miele, especially G7xxx models.
From what I've gathered, those do energy guided heating during the final rinse.
    629.3 KB
Thanks Henrik!
It was an Online order to store pick up. (I`m cheap I know LOL)
Anyway I`m not in their loyalty program and it`s been more than 6 weeks ago so I have very little hope for an exchange.
Will give it another try or two and if there`s still no regeneration will have to do something about it next week.
If necessary I will as you suggested get in touch with the seller first and if this fails I`ll contact the manufacturer.
Thanks again for all the helpful replies, 5 minutes ago the Miele did its first regenerating cycle. (What a relief... LOL)
A series of opening and shutting the water inlet while the pump runs continuously before the actual cycle starts.
First I had a talk on the phone with Miele which was kind of unprofessional and frustrating. Would have expected a little more technical support than what I can read myself in the instructions manual and their online product advertising.
I think everybody would also understand if they`d just say something like your question is going too much into technical details I`m sorry but I can`t give you an answer right now. Instead they give you BS like why do you want the DW to turn itself on or whatever else seems to pop up on their screen. And if you let them know that this was not what you asked about be prepared the friendly tone might change a bit.
So I decided to email the seller and Miele. As expected the seller refused to take it back and still waiting for a response from Miele.
Next I went into "programming mode" again just to find out I did not set it on 70°dH, it was on 7°dH instead. My bad, I hang my head in shame!
As to why it did not regenerate after more than 10 cycles when it was still on factory setting water hardness I can only guess that when I went into the menu to lower the rinse aid setting it might have thrown back the counting of water volume, number of cycles or whatever is relevant for the next regeneration as well. I don`t know, but it could explain it.
Anyway I`m glad I was patient enough to ask the gang and see what else I could do and not to bother a Miele technician come over immediately.
Now I'm wondering what is the regenerating cycle? I have a Miele dishwasher that is about 20 years old. I love it. It works great and I have had no problems with it. It does have a built in water softner. My water isn't very hard. I just fill it when the salt indicator comes on about once a year.
Regeneration of a dishwasher's onboard softener mechanism is the same process (altho on a smaller scale) as regeneration of a whole-house softener system. It flushes the resin bed with brine (salt water) to clear it of accumulated minerals (calcium, magnesium, etc.), replenishes with sodium ions for continued processing of hard water.
Miele has split that process into two phases.
The first flushes in the brine to the resin at the end of a cycle (either at the beginning of the drying phase or there about).
Assumption is that with the drying cycle and probably no other cycle being run consecutively, there will be enough time to for the brine and the resin to exchange ions.
The beginning of the next cycle flushes out the resin so the brine doesn't get used for any washing steps. That's what uses the majority of the water.
Ion exchange resins are somewhat of a black magic IMO.
They are about equally attracted to all ions in question for water softening.
All you do is overwhelm the resin with Natrium ions for regeneration - and then with other ions like magnesium and such for water softening.
They let go of what ever has a lower concentration at that moment and grab onto whatever is more prevalent.
Think it`s time for an update.
I`m still in love with the new Miele and don`t regret my purchase at all.
Like others complained before I must confirm the wobbly control buttons feel and sound cheap and the toxic chemical stench that came from the inside of the wash tub is not what you`d expect from an upscale German brand but most of it has worn off by now so it`s no big deal for me.
What I love most about the Miele is how shiny things come out, well that is as long as you know how to use it accordingly to your needs.
One of the many reasons I opted for the Miele was the possibility to have a second interim rinse programmed. After experimenting with it I have to say for me it would be overkill most of the time and I decided I won`t need it.
The old Bosch while also excellent at getting things clean from stuck on foods it always left an ugly film on dishes.
I suspect the heat exchanger pocket must have been gunked up and the fact that Bosch regenerated right after the main wash instead of before the cycle which also added even more of an ugly film of salt residue every now and then.
The Miele not having a heat exchanger seems way more hygienic in the long run. Well time will tell...
There is one exception however where dishes always turn out awful from the Miele, that is the combination of a partial load with light soiling on the Automatic program. This combination gives the most efficient wash cycle, even more efficient than the Eco cycle but it does not work at all. There`s only a grey water interim rinse where after a partial drain it refills with 1 liter of water then drains and does a final hot rinse with a very low water level and a reduced spray pressure.
The result is a nasty looking soap film on dishes and the inside of the dish washer and the residual water in the bottom of cups is extremely slippery between fingers as if things hadn`t been rinsed at all.
Even not considering myself a Sudsophobe found another cycle without detergent or at least polishing as much as possible off with a dish towel is absolutely necessary.
On the other hand the long drop off period followed by a drain and purge (a 3/4 liter of water flushing the sump while the pump runs) and a low level pulse rinse as interim rinse of the Eco cycle or on automatic cycle one step above minimum requirements is surprisingly effective. No complaints there.
However I found whenever I have a lightly soiled small load which I do have quite often it is best to use the Quick option along with Automatic or Eco. This makes sure I always get a purge and a full level interim rinse and sparkling results without the need of the second interim rinse.
One thing I couldn`t figure out so far is what it does exactly when I hear a knocking sound which occurs sometimes when the wash pump is running.
At first I thought it had to be the rinse aid dispensed because it does this twice at the final hot rinse but I heard this on a prewash and towards the end of main wash cycles too.
The relay of the heater BTW sounds more like a klick than a knock.
It`s hard to imagine rinse aid being dispensed during the cleaning phase of a cycle, it doesn`t make sense to me because rinse aid is acidic and detergent is alkaline. But you never know, have to say rinse aid is getting empty rather quickly despite of a low 2 ml setting.
Hopefully someone can shed some light on this.
Glad things are (mostly) resolved. 👍🏻
The 2nd interim rinse was the reason I was either looking at a Siemens with "Glanztrocknen" or a Miele. However, the equivalent Miele would have been twice the price, so...
I use the extra rinse practically all the time, as my hot water isn't metered but electricity is. With the dishwasher being connected to the hot water in my apartment, it hardly ever has to use the heater after the wash, as the two rinses provide enough heat. I would be the idea candidate for Miele's Solar Save cycle.
Great to hear you’re getting good results - I have noticed that this Miele gets stuff much cleaner and shinier than the Siemens IQ700 we had previously (although that was a lemon from the start, so not really a truly fair comparison).
Interesting ref the Auto cycle - generally more times than not we run a full dishwasher either moderate to heavy soiling so I have never had it trigger the small load setting (that I’ve noticed anyway). One thing I have noticed more compared to previous Mieles I’ve had is that it is less inclined to trigger a prewash on Auto (more often than not it goes straight to main wash), but it will adjust the number of rinses so overall there’s not any residue or yibbles left at all. If there is a load I really want a prewash on I will use the extra clean option (luckily I have it as an “extra” on mine without having to go into programming menu) which will force a prewash and additional rinse.
I find the Powerwash cycle very satisfactory for smaller/more lightly soiled loads - and you can boost it for extra soiling with Intense Zone or Extra clean to get a decent cycle with a prewash and extra rinse in around 1:45, or 1:15 if you select QuickPowerwash.
I will say though that 95% of the time I use the Auto cycle and let it get on with itself, and it has produced nothing but superior results, and leaves surprisingly little on the filters considering it only reminds you to clean them every 50 cycles or so. I will very occasionally use the 75°C wash for extremely heavily soiled items, or if I’m running the machine in the daytime and want things back quickly (if I’m baking or batch cooking) then either the Powerwash 60°C at 1:20ish or QuickPowerwash at 55°C in an hour come in really useful.
The other cycles seem redundant to me - Eco doesn’t dry very well due to the low temp rinse and spends over half of the cycle sat there drying trying to make up for it. You can select extra dry which then boosts the rinse back up to 70°C but then it will use just the same amount of energy as Auto. I also have ComfortWash and ComfortWash+ which whilst on paper seem good to have, I just find myself not using them at all in reality. And considering all my glassware is of the finest quality from a very exclusive and select Swedish home furnisher by the name of Ikea, I’ve never had a use for the Gentle cycle.
I have also noticed the same noise with the heater relay - it does sound similar to the rinse aid dispenser. I must say this is more economical than the Siemens with both salt and rinse aid, I find I have to use less even than the Siemens with Zeolith.
Interesting you note about the buttons - I actually thought to myself the quality of the buttons on the G7130SC we have as much better than the previous G6310SC I had in a former life, or on my parents G4940SC, but on the opposite side I feel the racks, although still of high quality; don’t glide as smoothly or feel as solid as on previous generations of Miele. I hope long term we see good reliability and longevity, but you can’t even expect that from Miele nowadays.
I know mine has the built in water softner but I have no idea when or how it works. I had a Bosch previously and I worked great. But my house was built in 1906 and the way hot water is routed it takes about 5 minutes for the water to get hot at the kitchen sink. I used to have to listen for the end of the wash, then pause the dishwasher until the water was hot and continue with the rinses. When I found out that Miele dishwashers could heat the water with a cold supply I didn't hesitate. I have a G894SCi Plus. Dishwashers weren't something that I thought about a lot but I love love love my Miele and have never regretted that purchase.
