Definition of Cold Water Washing
Chetlaham
Mar 11, 2013
5,416
United States
In the EU, generally, anything that doesn't require heating in most cases would be considered cold.
30C/86F would be low temp, but generally needs heating as it is above room temp. So wouldn't call that cold.
20C/68F could be considered cold IMO as under common circumstances that would be reachable without heating.
"Cold" isn't definable, so neither is cold water washing.
Some people feel 68F as cold in a room, I have my flat at 60-64F in winter and think that's fine.
So one could say anything that is using any warm water isn't cold anymore.
Or that anything under warm is cold, which could be as high as the 90F you mentioned.
I think major detergent manufacturers typically mean 30°C when they are talking about a cold wash for products sold here.
https://www.persil.com/uk/laundry/laundry-tips/washing-tips/temperature-use-wash-clothes-towels.html
My current machine has two hand wash cycles, one of which is cold, which I believe means cold as it comes from the cold tap, no heat. None of my previous machines even had a cold wash, unless you count rinse and spin. One did have a lower temperature button ( - 10°C), so could have gone as low as a 20° wash.
I find the concept of having arbitrary cold/warm/hot cycles like you have in the US very odd indeed. Normal wash cycles on UK machines state the actual wash temperature, which correspond with wash temperatures stated on the clothing care labels.
Cold wash reasonably refers to tap-cold input, vs. cool which is mixed with some warm. That's the method on "classic" machines with a 3-solenoid inlet valve and five temp choices (cold, cool, warm, medium, hot).
My F&Ps have six temp choices: (tap) cold, cold+, warm-, warm, warm+, hot.
In their German TV commercials "Ariel PodsCast", P&G suggest to turn the temperature down to 30C/85F to remove even heavy stains.
Back in 2009, Ariel Excel Gel was launched, claiming to effectively clean at 15C/59F. It's long gone from shelves here but still around in other countries, I think.
I guess 85F is what most manufacturers consider the lowest temp for effective cleaning over here.
I always thought "Cold" water washes here in the US were supposed to be at room temperature water, so around ~72 F.
I googled the Tide cold water and some were saying that they claimed it was effective down to 50 F, but "recommended" slightly more than that.
Here in the Chicago area, in our commercial speedqueens I cannot use the Cold temp option in the winter because they just turn on the straight cold tap with no tempering. This has long bothered me; our water comes in below 60 F I'm certain, and I've had issues with detergent not quite liking that. Back when we used the costco laundry pods, even with the deep-wash commercial top loaders I would find detergent gel from the pods undissolved on our clothes.
We have since switched to tide powder but along with that, we only use a coldest selection of "warm" in the winters. In the summer the cold water from the tap seems warm enough to dissolve the powdered tide and wash outerware just fine. We also now use the speed queen commercial front loaders instead. I’m sure that pre-dissolving the detergent helps.
What is the correct definition of cold water washing? P&G seems to state cold water as being a minimum of 90*F while Whirlpool defines cold water as being between 55-65*F. When detergent manufacturers talk about being able to wash in cold water, what temperature do they have in mind? Why is there such a discrepancy in listed temps?
https://pgpro.com/en-us/brands/tide-professional/tide-coldwater-system
https://producthelp.whirlpool.com/L...ting_Cold_Water_when_Warm_or_Hot_was_Selected
These corporations think we're stupid.
If anything, they can not agree on an exact definition. At least not publicly.
From an old Maytag service manual, it seems that the target water temperature on the warm setting for a thermostatic mixing valve was 97*F plus or minus 5*F. Medium water intended around 124*F, cool water between 97*F and the cold inlet temp, and hot water around 150*F.
Granted, older detergents were soaps, however, from my own experience even modern detergent works best with water around 105*F.
Clearly, when energy was no object, an ideal temperature had been defined and established.
    149 KB
    116.6 KB
I was wrong about the single cold wash cycle on my current machine being unheated, according to the service manual for the board, the hand wash cold cycle is at 20°C.
