The 1938 Frigidaire Bolt-Down Automatic Washer!
Unimatic1140
Administrator
Staff member
Apr 26, 2001
10,128
Minneapolis
AI is getting to the point where it can recreate patents of early automatic washer designs that were never marketed to the public, it's not quite perfect yet but it certainly is better than it was 6 months ago. We can learn about the history of the design and creativity of the architects and engineers of our beloved machines. Had World War II never started we probably would have seen some these machines come to market in the early 40's.
This one is incredible. It is one of the very first patents General Motors received for their newly designed automatic washer. It was larger than the standard automatics we know today because of the three 10 gallon water tanks incorporated within the back of the machine.
The machine could wash three 8 to 10lb loads of laundry using only 50 gallons of water!
Introducing the 1938 Frigidaire Automatic Washer!
Check out the inside of the machine, the coolest thing ever!...
Here is how the machine works according to the patent:
The user places the wash load into the wash basket. Then she removes the rear cover over the water tanks. With a hose connected to the sink she fills the Wash Tank with 10 gallons of hot water and adds the soap or detergent to the Wash Tank as well. Next she fills both Rinse 1 and Rinse 2 tanks with 10 gallons each of warm water. She selects the wash time wanted from 5 to 20 minutes on the "Wash Period" dial and turns the top dial to "On". From here on out she is free to go onto other things and the machine runs all by itself.
The washer then does the following according to the patent:
Wash load #1
#1 Pumps the detergent laden hot water into the wash tub up from the Wash Tank.
#2 Washes/Pulsates the clothes for the desired time as set on the "Wash Period" dial.
#3 Spins the wash water up and into the upper drain trough and the soapy wash water is then directed back into the Wash Tank to be reused for the next wash load later on.
#4 Tub stops spinning and water is pumped into the wash tub from Rinse Tank 1.
#5 Machine pulsates clothes in the rinse water for a couple of minutes.
#6 Machine spins first rinse water into trough and then the diverter valve sends the 1st rinse water right down the drain. The first rinse water is never re-used in subsequent loads.
#7 Tub stops and water is pumped into the wash tub from Rinse Tank 2.
#8 Machine pulsates clothes again in the rinse water for the second rinse for a couple of minutes.
#9 Tub spins the water into the drain trough and the 2nd rinse water is now diverted into Rinse Tank 1. The 2nd rinse's water is now saved to used in the next wash loads 1st rinse!
#10 Machine spins the clothes damp dry and they are now ready to be hung on the clothes line for drying.
Wash load #2...
The user re-fills Rinse Tank 2 with 10 gallons of fresh clear warm water for the next load. The other two water tanks are filled from the previous load.
The user can place the 2nd wash load into the washer. It uses the saved hot wash water (which has now cooled down to warm) for the 2nd load.
Wash time is set and the machine started and runs through the same cycle again saving the wash water and last rinse water.
At the end of wash day or if the user wants fresh water she turns the drain dial to "On" and the machine drains all three water tanks.
Fascinating to say the least!
Here are the images from the actual patent that I used with AI to create the photos, you can read the patent here: https://patents.google.com/patent/US2325837A/en?oq=US2325837A
I imagine that Maytag ‘wobbling ball’ spins in a continuous circle and had some sort of gear reduction or belt slippage to make it simpler. Probably washed like the Bendix PowerSurge of the era from what I can imagine.
Loved this.
Would the Frigidaire Rollermatic that Consumer Reports totally dissed in their 1969 Automatic Washers report now qualify as a bona-fides water saver? I wondered how and why CU would take a once Check-Rated Brand and throw it to the wolves. And yes, I remember that the big negative was its small capacity and then, of course, was the universally terrifying issue of sand disposal. Don't get me wrong, I still respect and miss the Consumer Reports of yesteryear, but I thought that whole report was questionable in many ways. I'd love to find another Rollermatic with all the bells and whistles.
Well my post go deleted, seems like we must agree to that ridiculous artificial dumbness here...
Throw your brain to the trash, you don't need it anymore...
Your post makes zero sense to me what so ever. While the majority of us here love real vintage machines, me included, that’s exactly why I thought it was exciting to visualize patents that never made it past the paper stage. It isn’t meant to replace actual history or the engineering of machines that were built, it’s just a way to explore what might have been and bring old ideas to life. I genuinely don’t see how using AI in such a harmless, historically curious way should spark such a strong reaction. If I had the artistic skill to paint or draw these designs myself, I would have done it years ago, but I don't and these tools finally make that kind of visualization possible. There’s plenty of room in this world for both traditional collecting and historical reconstructions.
This AI boom is sparking creativity in so many ways we never even dreamed of. We are also so lucky to now be able to make up brand new styles of machines, sparking both new ideas as well as some fun and silliness. In a few years the tech is going to be so much more powerful I can't wait to see what we can do with it relating to the vintage machines we all love.
Well said, I am finding people who are instantly attacking AI generation, a phobia , an aversion of some kind automatic it appears . I say keep scrolling you input goes nowhere today. AI is here get used to it.
Personally over the years I've discovered that people will attack anything that is homemade, self made or uses imagination. Before AI I would draw up various designs and use photo shop to render improvements to existing appliances or to depict those that were never built. Only to have people shout me down saying I shouldn't because it was all fake, that I was impersonating a professional, that people repairing their machines could confuse my concepts for the real thing, ect, ect. Why this brings out such animosity in some people I still have no solid idea however I see AI used for this purpose as a good thing. So many great things will come from being able to create new designs and improve on them.
It won't be long before people start designing and printing their own appliances which is a dream of mine. No more having to hunt and fight keeping old machines in service with limited parts. Personally I would 3D scan an existing dependable care, program my own cycle control system that suits me best, print out all the parts, assemble them together, and voila!
Do you disagree with your post being deleted or do you disagree with the AI renditions of washing machines shown in this thread?
Just curious. I am all for AI, but not AI moderation if it was ever implemented here.
Hi post was not deleted by an admin (it wasn't me btw) because of the subject matter, his post got deleted because he used profanity about the AI in this thread.
But it was a human that deleted it, correct? (I have no issue in profanity being removed, I am all for that)
Thank you for clearing this up. I love all these AI pics and AI generated machines:)
What makes no sense is to use ai for everything just to blindly follow that new trend...
Ai boom isn't sparkling creativity, it's killing human creativity and even start to kill some human jobs...
By the way is your post written by yourself or by artificial dumbness ?
AI isn't just about artificial creation, it could also simulate all the dynamic forces and fault trees on a design and then alert the user to the points of failure and how they could potentially be rectified before a machine is printed out. Few if any people can very accurately predict how any given design will function in a lab or reality. Making those tools practical will be a game changer for everyone.
And do you think it's normal to be attacked by creating homemade things ?
DIY is cool when it came from human thinking, that's why I like the machine designs and concepts you created by yourself.
I've also drawn a lot of imaginary machines schematics and timer charts, it's like crossed words for electrician.
Sure 3D printing all parts of a timer will be amazing, although a lot of parts can be made more easily without the need of a 3D printer.
If an human would draw images like ai does, the majority of peoples with critical sense (those who cannot think by themselves tends not have it) will say it's piece of shit...
Ai moderation on F'assButt, enough to write books about it...
Well I haven't attacked anyone but ai (which isn't a person at all).
Peoples are dead for freedom of speech, don't forget that.
Not phobia at all, just common sense, turn off the power of data centers and see who wins.
Artificial Dumbness fanboys follows blindly what ChitGPiTy said like it's a new 'religion', not able to think by themselves anymore...
Can you post some of your machine schematics and timer charts to AW.org? I'd love to see those.
Sadly, it is normal in the sense there are those out there who chastise independent creativity and out of the box thinking.
Here’s my 2 cents, I have no problem with AI being used to bring patents to life, recreating scenes and remastering photos and videos from a bygone era.
However, I do have a problem with AI being used to create music and ripoff artists, certainly have a problem with AI being used for nefarious purposes, along with putting unnecessary AI in appliances when algorithms worked fine for decades.
Another issue I have with AI is how much power is used to power the data centers along with the amount of water that’s used to cool them, not to mention the amount of carbon dioxide they emit into the atmosphere.
That being said, I don’t have a problem with AI, just when it’s used in excess, used to ripoff artists, used for nefarious purposes, the amount of resources required to run a AI data center, that’s all.
Not that it is any of your business but my post was written by myself, although built in browser AI corrected some spelling errors and suggested some grammatical changes which I absolutely appreciate.
The way I use AI is absolutely sparking all new kinds of creativity, I 100% disagree with you on that it is not. As Jetcone-Jon said AI is here to stay and it is producing amazing results already.
Warning: When I use AI and it creates something really cool that is washer related I will share it here if I so desire, you may want to block me now before your break you string of pearls.
I'd like to but no one will be able to read or understand my (left) hand written symbols and coded abbreviations.
That shouldn't be normal, thinking with boundaries isn't thinking...
Yes art ripoff is one of the worst thing.
A lot so called ai algorithms are just overcomplicated programs with hidden spying features.
Don't tell the secret, no one's want to know how much power & water is required for that...
