GE Double Door Refrigerator GSH25JSXNSS Fan Switching To High Speed and Freezing
Chetlaham
Mar 11, 2013
5,403
United States
Hi, I have a GE GSH25JSXNSS double door side by side refrigerator and freezer where the freezer evaporator fan keeps switching to hi speed. Previously it did this only a few minutes when coming out of defrost or the door was left open for more than several minutes. The past week it has been switching to high speed several times an hour without the door open, and will stay this way for up to 15 minutes. Also, I've noticed things like a gallon of water are freezing on the top shelf where they previously did not. A refrigerator thermometer says the fresh food compartment is dipping to as low as 30*F despite the fridge section being set to number 7 out of 9.
What would cause this? Bad thermistors, control board or dusty condenser coils? Something else? Or just normal for this time of year? Should I just wait to see if it will go away?
Read the GE service manual for any SxS since the year 2000. "Liner protection mode is king!" When ambient air hits frozen plastic, it can crack. The fan is variable speed. I never leave the doors open more than 2 minutes. That makes it defrost sooner and more often. I'd rather have the fan running without the compressor as much as possible.
So the fridge knows the gallon water jug is inside it and is compensating?
The evaporator fan 99% of the time only runs when the compressor runs. But if the interior air temp gets to warm, the evap fan will switch to high speed.
Edit ok, that makes sense. It knows if the door has been open for more than 3 minutes and kicks into high speed.
Though I still don't get why its happening with the door closed for several hours without being touched.
Mine is a 2007 model 25.4 cu. ft. Ever since I can recall, the door alarm has gone off every few month's when closed. At this stage, it really doesn't owe us much. I check the temps. occasionally. I can tell when it's ready to defrost because the fan hits the icy evaporator.
Modern? Oh to live in a perfect world. Nothing and no one is forever. Had appliances never needed repairs in the 60's, 70s, 80s, and early 90s, my dad wouldn't have been a Sears servicer for 33 years. We ate good, etc. Their 1967 Coldspot bottom freezer Spacemaster "16" compressor failed after 4 years. Only had to pay the labor. My 1974 GM Frigidaire car A/C was nice and cold but repeatedly blew thermal limiter fuses.
GE is a scam and they've gone downhill since the 1990s. Stay away from GE! Remember their laundry and dishwashers? The same applies to all of their appliances.
Ok, so I vacuumed out the condenser and it seems to have helped- for the most part. I still had one instance of the fan switching to high. Hopefully its just the fridge coming out of defrost or something.
I hope its not a refrigerant leak- the high pressure line leaving the compressor was very hot, but not super painfully hot like I remember when I had the back cover off the fridge 10 years ago. Hopefully its just a lack of cooling load.
Update: The condenser is clean and air flow is better. And while it helped originally, the fan has been stuck on high speed these past 2.5 hours. Fridge is around 35*F mid shelf, freezer is dipping down to -15*F. Its cooling but the fan has me going paranoid something is about to give out.
According to the owners manual, both freezer and fridge controls should be set to "5" initially.
RTFM
Oh, it isn't an Artica or later model with led digital temps.? Ours says 0 for freezer and 37 for fridge, which is the plug in default settings. We keep it at 3 and 38. Temps. drop from tie to time to 35 and 1 or minus 2. Our neighbors have an Artica in the garage that was icing up. Removing the plenum tower in the fridge side helped.
As for new appliances, GE still makes a great oven/cooktop/range, and I'd rather have a new GE fridge over an LG or Samsung, but maybe it doesn't matter anymore.
I have it at 8 & 7 which I find the most optimal. Though bear in mind the fridge was made by Garbage Electric, so, those numbers might be a bit arbitrary relative to what is low, medium and high.
Whatever 0 degrees for freezer and 37 degree for fridge so something is not telling the the correct temp. Call a pro or buy a new fridge. Sometimes even DIY'ers or former pros need help.
I am going to put the other thermometer in the freezer to see if there is any major discrepancy.
Theoretically, how low can a residential R134A fridge freezer system go if forced to run to its limits?
Apparently, the ideal temp for a freezer is 0 degrees.
You mentioned it's down around -15 degrees.
I'd back off the control to align it with the suggested temp, there's no reason to Super-Freeze things.
Well, I think I might have at least one defective thermometer. One is showing -10, the other 7*F.
-15*F might actually be around 0*F.
Ta ordered a Taylor and will come after that.
I used my digital cooking thermometer to check my fridge temp...if you have one, at least try it in the fridge...until Taylor is delivered.
I suppose that would work too.
My digital cooking thermometer is a Taylor that reads -40F to 450F.
It also has a "hold" button to lock the temp reading, so if used in a freezer it can hold the immediate temp from raising before you remove it from the freezer.
You just gotta hit the hold button fast when opening the door.
Chet, You can hear the damper door actuating if it is working. You need to stay near it for a while to tell. Unless another problem is preventing it from operating?
I heard it a few times make that gear noise, but it does not seem to be opening. No cold air is coming out of the slots.
It would make a lot of sense as to why the fan is not modulating. If the damper does not open enough, not enough cold air enters the fresh food compartment and it gets to warm. The thermistor senses the elevated temperatures and switches the fan freezer fan to high. At least that is my theory.
Ya see... that's the trouble with all these "modern" appliances today.
Over-engineered, over-designed, trouble-prone hunks of crap.
I imagine that regardless of the brand name, that they hire some smart young Geeks to design these things, the higher-ups then accept the "impressive" design, and it goes to the fabrication lab for testing.
Voila!...... a New Model!
The simplicity (and reliability) of past products is forgotten, considered boring, old,.... no!, let's "fancy it up" with lots electronics! - "It's sure to sell if we put a bunch of lights and touch buttons on it!"
And we'll Outsource the manufacturing to some off-sea child labor factory to increase our greedy profit margin!"
My lowely old 1985 GE fridge has a "damper" adjustment for the fresh food section - it's a "boring" manual mechanical rotary knob that changes the amount of freezer air that little flapper door sends through.
And I've had absolutely no issues with the fridge, other than the occasional cleaning of dust on the coils underneath the fridge.
And you may wonder why I stick to my "old" appliances?
Because I'm a smart old bastard that doesn't want to be chained to the "Upgrade" propaganda influenced crowd.
And now you understand my anger, my passion, my activism.
30 years ago my double door would have been nothing but a plastic piece for a damper. Now its motors, sensors, algorithms and well you see the outcome.
I spoke today with someone who recommends buying a new fridge. Of course because its a sale for them, but at the same time you truly are buying a disposable napkin meant to secure a soon to be future sale of another disposable napkin.
