- Joined
- Nov 24, 2025
- Messages
- 11
I'm either blessed or cursed with the ownership of multiple properties. But, I work in two different cities and we have escapes from both. We have a SQ stacked setup in two places. I noticed the other day when looking over the manual that SQ says if you are using wash pods to just throw it into the drum and not use the tray ? Now -- I hate the SQ pull out tray for the soap and bleach as it feels cheap and I can't read it! I also don't use it enough to remember the tray layout. It seems the washer fills with some water and then drains on the initial cycle? The water that washes out the tray is much later and seems to be in the second longer fill. Am I missing something about the initial cycle? If I am right the pod will just be washed away. We have a GE set at the beach and I use the tray for the pods and it's never a problem. Why would they make a unit that can't use pods? I am a manual reader so I'm surprised I missed this but I did not install the units and I'm only reading now because of a problem with the initial install (venting)
