Speed Queen front load detergent/ dispenser/ cycle question
TAG
Active member
Bronze Member
Nov 24, 2025
30
I'm either blessed or cursed with the ownership of multiple properties. But, I work in two different cities and we have escapes from both. We have a SQ stacked setup in two places. I noticed the other day when looking over the manual that SQ says if you are using wash pods to just throw it into the drum and not use the tray ? Now -- I hate the SQ pull out tray for the soap and bleach as it feels cheap and I can't read it! I also don't use it enough to remember the tray layout. It seems the washer fills with some water and then drains on the initial cycle? The water that washes out the tray is much later and seems to be in the second longer fill. Am I missing something about the initial cycle? If I am right the pod will just be washed away. We have a GE set at the beach and I use the tray for the pods and it's never a problem. Why would they make a unit that can't use pods? I am a manual reader so I'm surprised I missed this but I did not install the units and I'm only reading now because of a problem with the initial install (venting)
Speed Queen front load washer dispenser systems
The dispenser drawer is smaller on Speed Queen front load washers. They were worried about people putting way too much detergent in because it is a commercial machine.
If you put pods in them, they sometimes will get caught and not flow into the outer tub and it will cause a water back up
And cause a leak I’ve done several service calls for this problem. The pods are designed to go in the drum unless the manual for the particular washer you have says otherwise most front load washer should not have pods put in the dispenser.
I don’t know why the washer would fill and then drain out some of the wash water unless you’re using the pre-wash cycle, which does dispense the detergent in the right rear compartment and then drain out all the water and spin a little bit and then it dispenses the detergent in the right front compartment
I agree with you they could be better labeled, but it’s not hard to learn both. The detergent compartments are on the right. The fabric softener is the left rear compartment and the bleach is the front left compartment.
Hope this helps John
My dispenser leaks. Not every time and I'm not dumping huge amounts of detergent sloppily into the drawer. But it leaks and makes a big mess and don't know why. The detergent drips out the bottom of the drawer and then flows down the front of the machine. It's not a lot, more like a single trail. But it's happening and very bothersome. Anybody else, Speed Queen Front Loader Detergent Drawer leaking? I figured out how to remove the drawer to clean up the mess, you press up on something on the underside, and you can see that a pod would definately NOT work.
The problem I've had with pods is they get flung into the gasket area early in the wash cycle, and there it will stay for the whole cycle, never getting splashed with enough water to totally dissolve and no mechanical action to break it apart. I gave up on pods, they're a mess in this front loader.
    67.8 KB
    138.3 KB
Interesting on the drawer removal did not know it came out. Nothing too complex in there from your picture !
I assume the flow is temporary and not the way the washer fills? The drawer is a cheap execution of a questionable design.
I can see how there could be a back up if anything got in there ... do you use powder? Mine has never back up and I never gave a thought to the pod not fully dissolving due to the water flow -- or at least the sound of the flow to the drawer.
Guess I should switch to liquid -- that's a pain with front loaders especially this one. I hate trying to pour beach. No washer should be built today that can not use pods -- especially fronts
We have these in my condo. They do indeed do a quick fill and then tumble and drain. It is rather stupid because it will definitely lose whatever detergent was not soaked into the clothes. It’s more akin to the pre rinse of a dishwasher rather than the optional extended pre soak of a residential machine but you can’t turn it off.
Beyond that, we have seen issues with the casing of pods collecting in the door seals area too. These machines just aren’t designed for pods at all.
A tablespoon or two of powder in the drawer is your best bet. I put one in the prewash spot and then another in the main wash.
I have two SQ f/l washers as well, one a 2004 model (small door) as well as a 2017 (larger door, new balancing system) and both dispenser drawers are a weak spot in the machines. They both have difficulty dispensing at the correct time, the older model seems to dispense everything all in the first fill occasionally and the newer machine with a slightly updated dispenser design doesn't fare much better. I really do not use the dispensers, if adding softener, I wait until after the first fill before adding it to the drawer. We have had no trouble with the pod detergent, my son does mostly large loads, adding the pod to the empty drum before the clothes so that may help.
Took some more pictures of how this thing works. The holes on the roof of the dispenser drawer housing is where water enters the tub aimed down into drawer compartments. Holes deliver water to different compartments at different times during the cycle. I suspect splashback is happening and that's what's causing the leaking of detergent out the front of the drawer.
The MAX marking on the main wash compartment on the right doesn't make sense. You could pour an entire bottle of liquid Tide into that compartment and never reach the MAX line as everything poured into that compartment immediately spills out into the back and enters the tub.
    164.1 KB
    75.2 KB
Is there perhaps mineral buildup on the shower holes that's causing misdirection of the flow?
Four dispenser compartments (prewash, main wash, bleach, softener)? The main wash compartment on frontloader dispenser drawers (particularly if a prewash or delay start function is present) typically includes an adjustable/removable barrier/dam or cup for liquid detergent to hold it back from running out until the water flow engages to flush the compartment at the proper time.
IMO --- Not enough water enters the SQ tub. We had an under counter Frigidaire set at one time that we really liked. Those old sets w/ the gas dryer had a cult following in the city where vented gas was preferred and space was at a premium. When you looked in the door you could see the clothes flipping around in the water. You could do a down pillow. Much different than the speed queen that looks more like wet clothes flopping in the tub. Doing laundry should not be this hard.
Try having a beach house with almost any new unit today ... frustration. In many cases you are often only there for a couple of days with lots of laundry generated -- towels and beach stuff. I had to laugh years ago when my neighbor at the beach got a new Bosch set and reported that it held his clothes "hostage" for hours. It's why you see so many new luxury homes at the Beach with two washers ... crazy. The old top load Kenmore units are finished in under 1/2 hour and on high the dryers need a bit more to dry the load. They also have settings for double rinse and soak ... I bleach everything. The double rinse in great for 1/2 loads when heavy bleaching ... overall you use less water and the second rinse gets you better results.
We really have gone backwards.
I will counter your opinion, why used pods. They cost more money and you are using a predefined amount of detergent, which I assumed is for a large load . Pods should not exist. And if you are so not sure of something, I have called Speed Queen/Alliance, 3 times since I brought my TC5. They are knowledgeable.
Have you ever looked at various detergent labels ? Take TIDE ... they make a few different formulas and each has a different amount to use. Typically the big container at the big box stores is the least powerful -- needing the most detergent. Also - not all of them are suitable for HE washers due to the suds. This is true for the pods as well. I can tell you -- no one in my family is going to read and measure to see what one we are using. SO -- my guess. We use way more than needed when using liquid in the place with the top loader. I buy the basic tide at that house and transfer it to a smaller TIDE container because the big ones are a pain to use. I do the same with bleach . The pods have much less in them vs what we would use. My guess is the pods have to contain a very high concentrated formula because they are so small.
The post are for "ease of use" IMO -- especially in the front loaders where any dripping is going on the floor. That why I was surprised when I read the manual and it said not to use them. I have not been to either house to confirm that they also both do a small prewash and drain -- That was my initial observation. I was not specifically watching the unit for this reason but I'm almost positive I heard it pump out before filling up with more water.
I always use the pods in the dishwasher .. it's just easier and they work very well. I also thought the multi formula was a gimmick but without question they work better for general kitchen stuff and glassware. I do have powder as well but only use it when I toss in the stove parts and use the long cycle with the prewash -- I use the powder as the prewash.
Yes use PODS for Dishwashers: Ease of use, they clean better and new machines with one dispenser are designed for PODs, so new machines no choice. I missed the tubs of Electrosol (Finish) purchase from BJs, cheapest cost per load.
Yes, I look at detergent labels since I moved out of the house 40 years ago. I mainly use the cost effective brands: Purex, All, Arm & Hammer, Fab/Dynamo and Simply Tide. I used Tide for pretreating bad stains and extremely dirty loads. Pods in a washer are again a waste and ease of use does not counteract that. But if you want to go ahead, whatever helps you through the task of doing laundry
Speed Queen front load washer dispenser leaks down the front of the machine
If you have very strong water pressure, they do this sometimes Speed Queen has a different inlet valve that restricts the flow a little bit to fix this problem. If the machine still under warranty, the warranty will pay for the valve. The valve is not real expensive.
Reply number 12 those are the five worst detergent you could possibly use well there’s probably something else is bad. They’re all very weak. I bought some of that simply tied in the yellow bottle one time and it was worthless. I took it to work and we use it to wash rags where we don’t really care how clean they get.
If you’re looking for cost-effective, but excellent detergent try something like Kirkland signature detergent from Costco, Aldi has an excellent detergent. Their premium store brand is as good as the premium tide, there are other good store brands as well if you’re trying to save money, but the national brands that are inexpensive or almost always. The worst detergent made just check consumer reports for example, they’re near the bottom of the list.
John L
John L
Not a Costco member and as I stated if I need to get a stain out, use tide. Most times you do now need the best . But being a site compose of laundry experts, repairman, no one will state otherwise,because they believe you need the best. Plus Tide oversuds which can cause backup in sewer system ..that has been an issue since 1970s.
Its not that we believe you need the best to get good results without ruining your machine in the process, instead we know real detergent and hot water does the job based on actual experience, observation and knowledge. Cheap detergents are nothing more than liquid fragrance. They just cover the dirt. They do not clean clothes while causing scum, dirt and buildup to accumulate inside your machine leading to problems down the road. Good detergents actually save money because they do the job at a lower dose. If you're getting to many suds with Tide, then you are overdosing which would make sense if you are used to adding large doses of cheap detergent to your machine.
If you really want to save money while actually getting clean clothes, buy this:
Your wallet, skin, clothes, machine will thank you. I use Tide almost exclusively and my clothes are so clean they do not need fragrance of any kind. In fact Tide pro got rid of the scum lines in my machine that other detergents caused to form over the years.
