Battery chargers...
cfz2882
Feb 9, 2010
2,725
Belle Fourche,SD
...mostly those meant for 6 or 12v automotive batts,but other types too :) Once saw an old 6 volt one at a rummage sale that was probably from the '40s that had a half wave tungar tube rectifier-probably quite a voltage drop across that tube. Some pre-1950s chargers used a copper oxide rectifier.Selenium rectifiers were the usual through the '50s and up to about 1989 in certain models. Silicon diodes began about 1961. Oldest charger i have in active use is a big one about 30 amps from 1966 and silicon diode. a 10 amp selenium one from 1979 and a couple recent 6 amp Schumacher ones that use a little switching power supply instead of a 60hz iron transformer-these little ones work very well,but are automatic and will not charge a 12v batt from all the way dead-only charges those up to 6v...
I have a charger that is probably from the 60's, if not older. Unlike modern junk from the last 30-35 years that will refuse to charge a battery once voltage drops down to a certain level, this baby will charge anything regardless of how dead it's. Yesterday, my neighbor was complaining his charger refused to charge a battery in a truck he rarely uses. I told him to bring it by, mine will 😁 Almost fully charged in 24 hours.
good old charger-very likely a pair of selenium plates against the back panel, smaller chargers the rectifiers rarely give any trouble but larger versions the springy brass contact disc against the sputtered on lead layer can get bad connection over many years-especially if gets wet-and arc: letting out some nasty smelly red smoke :) If caught in time-weak output, but no rotten egg stench, can be fixed by carefully cleaning the contact disc and where it contacts the lead film over the selenium layer .
I keep a couple good old ones around, no stupid electronics to check the polarity before the juice starts flowing, if I hook it up backwards, that's my own fault! I think DeWalt and others love the new designs, I had 4 "bad" batteries on the shelf before I learned they need a little boost to get the charger to start if they're stone dead...
It's best to charge batteries slowly, they last longer. Originally used the famous battery Tender brand, but they never last more than 2-3 years, and they don't honor warranties
Now I use one of these, I bought it at least 15 years ago for my bikes, discontinued now:
https://www.amazon.com/dp/B00HZTDKZG
May be why I always get 9-10 years from a battery. If the car is going to, or has sat for a while, it gets attached. I also attach it for 24 hours whenever I get a new battery.
I have an old 6 amp just in case, but never have a use for it.
Most of the time, we get 2-3 years out of a car battery, no matter the quality. Driving in summer in Phoenix with the A/C blasting in 115 degrees cooks everything under the hood, probably 160 degrees. If the battery is someplace else, they can last forever. I have an old C class Benz that has it's battery behind the firewall, with the A/C outside air supply pulled through the same compartment. I've gotten 8 years each out of two of the batteries it's had.
I use a 0.9 amp battery tender that gets rotated on my own cars, trucks, and lawn equipment. However, every once in a great while shit happens and old Betsy comes out to save the day.
Yep, that's why I keep the old 6 amp around, just can't remember how long it's been since I needed it, probably at least 20 years.
It was my dad's, probably from the 70's, maybe older. He had it before I got a license in 1980. It's a Montgomery Ward brand.
