Thanks Martin,
I'm doing it as much for myself, to log the info here, as for anyone, I suppose. But I'm glad to see someone is reading it.
Here's what happened today - Getting down and dirty
"I'll just fiddle with a couple of things"
"I'll save time by lying on the floor next to the washer, I can just reach in and adjust the clutch spring tension...."
"I'll just loosen those 3 screws, then I can adjust that tensioner...oops the screws came out. ok I'll just reach up with my 3rd hand and adjust the spring seat on the cover to ....#@$#%$"
---So I ended up with parts looped over the agitate arm, and up and down the agitate shaft. dead end.
In retrospect, considering how easy it is to grab that coupler with channel locks and hold the tub, I should have just unscrewed the coupler in the 1st place. The clutch nut was only finger tight on the cams, so everything came loose slick and easy once I had the coupler off. It will be better having it off, that way I can clean the dust out of the cams and lengthen the anti-rattle springs. etc.
Disassembling the clutch is easy, but the shoe/brake dust makes a mess. Have some brake cleaner handy, and some sand paper to deglaze the shoes.
I think I may try polishing up the OD of the clutch where the roller contacts, it was showing a rough worn finish.
