sudsmaster
Knob and tube
As originally and professionally installed, knob and tube is actually quite safe, esp. when the fuse boxes have been upgraded to circuit breakers.
The problems with KNT wiring arise when:
1) Homeowners extend it by inexpertly splicing into it, overloading the 20 amp wiring
2) Someone overlays the wiring with cellulose insulation in the attic. If there is condensation in the attic (common) or a roof leak, the cellulose material gets wet and conductive, potentially leading to shorts and fires.
3) Even non-wettable insulation over KNT wiring can be a problem. The wiring is designed to heat up at max load, and cool off by radiating heat to the surrounding air. If it's buried under insulation, it may not have the opportunity to shed heat and can get overly hot, causing insulation to deteriorate.
4) Some older extensions of KNT, such as to ceiling light fixtures in closets, added after original construction, may have used substandard wiring with extremely brittle insulation. These need to be replaced with modern, safer wiring.
5) Most KNT wiring provides for no ground wire. This can be a problem when trying to run larger loads such as modern washers, dryers, fridges, etc that have grounded plugs. It also can be had to find non-grounded outlets, so when the original outlets wear out, there's a temptation to install grounded outlets without a separate ground wire, which then result in a floating ground.
