geoffdelp
Hi all ... thought you'd all like an update on my Maytag 101P.
I thought I would NEVER get it running, but had success over the long 4th weekend. I got a new timer, but it was the wrong one and will return it. I was so frustrated that I started to clean all of the contacts and reconnected everything; it STILL wouldn't run!!
It finally dawned on me to disassemble the lid (I'd already done that once) and sure enough, the unbalance mercury switch was in the "tripped" position. It had been rigged with wire and a spring because the eyelet that the spring connected in to had been eaten away. I flipped the switch forward, closed the lid and VOILA, we made contact and little 101P started to agitate right away!! Even the little "Maytag" light lit up!!
The bummer? Well, it won't spin. I can hear the solenoid trip and can hear the brake release, but it just won't spin. I think it's the "T" key and will try to remove it soon to see if it is worn.
The other bummer? It made the most horrific scream during agitation and when it tried to spin. It sounded like someone trying to start a car over and over again. I'm guessing the bearing that the shaft runs through is extremely dry and will try to get some lubrication on it first.
Other than that, I CANNOT WAIT to get her painted, cleaned-up and put new hoses on for a long anticipated "Maytag Wash" - 1954 style!!
Geoff
Geoff
