1935 Maytag model 30 - - - pics of open gear box
bradross
Feb 21, 2008
734
New Westminster, BC., Canada
Hello everybody,
I'm sure most everyone remembers two years ago when I restored a 1935 Model 30 Maytag wringer washer (purchased from Hardware Hank in Early, IA.) Well, ever since, I had wished that I had initially disassembled the entire machine to have a look at the power drive / gear box. I suspected that the cork gasket has long since disintegrated because there was always a slight oozing of grease at the seam.
So...I finally bought a decent set of ratcheting wrenches and tore the machine down. And yes, I'm replacing the cork gasket so the little oil leak problem should be fixed at long last!
Here are a few pics - a very simple mechanism but beautifully engineered and well-constructed. That's why these machines last "forever"!
Pretty cool Brad!
That looks completely different from the transmissions on the later E,J, and N's. Was it easier to get to do you think? It looks like you just disassembled it from the bottom of the wash tub. Whereas on the later models you had to remove the inner tub to get to the unit which I'm imagining is more work.
Yes, Larry, it's completely different from the E / J / N
In the old "gray ghost" machines, the worm screw drives the "worm gear", which is the primary drive for the wringer post, whereas in the later E / J / N models, the worm screw primarily drives the agitator gear, with an "offshoot" for the wringer drive. That ultimately made for a much smaller power unit.
The tub had to be taken off the legs and the top portion of the power unit in order to separate the two halves and replace the gasket. Those bolts were extemely hard to loosen (after 79 years!) but my new wrenches worked well.
Two gaskets needed replacement: 1). for the power unit itself (part # 13067), and 2). between the tub and the top of the power unit, for the agitator gear/clutch opening (part # 13066).
But, as is so often the case, a repair job takes MUCH longer than anticipated. The first gasket material I bought (Fel-Pro Karropak - fiber paper, 1/32" thick), worked well to reconstruct the gasket for between the tub and power unit, but was too thin for the larger gasket. Of course, I didn't realize this until I had the whole thing bolted together again! So I bought 1/8" Fel-Pro cork sheeting from the automotive supply store. It was ever so slightly too thick, and I didn't realize this until I tried to bolt the tub back down and had difficulty aligning the bolt holes. In any event, with a lot of patience and elbow grease, I got the machine back together. Just need to do a little spot painting where I made a few scratches getting bolts off, etc., and that "little" job is done! Looks like it made an excellent seal, so shouldn't have any grease leaking again - in my lifetime, at least! This thing should last into somebody else' s lifetime now!
