1949 Antigue TV console w/Radio & record player - $375 (Jamaica, N.York)
I can't make out the brand on this.  The picture tube is probably fine.  It's the capacitors that have likely gone bad.  Not a difficult thing to bring back to life for someone with the necessary expertise, but they need to knock off around $300 from the price.
Concur!
Ebay and some other prior sales histories might be the source of the far-flung pricing.
Louis - do you happen to have an ad or catalog description of this model?
Wedgewood
Actually, I thought it was a 1949 model. :-)
I like those old Maggies from 1949-51. The closer to 1951, the better.
Those Windsors....especially...are works of art.
Thanks Louis - found it!
Yes,recap the unit-and for the screen-appears that both the safety glass screen over the CRT screen will need cleaning.Shouldn't be that hard to do.The TT will most likely need to have the idler tire cleaned-replaced and the motor lubed-same with the TT mechanism.Once restored-this would be a nice unit.Would be perfect for watchin g old shows on.The case looks like its in fine shape-had some care.
